thanks for the feedback. Which 5.xx are you using ? 5.0.x is still maintained (though 6.0 is recommended for any new study), so I can try to fix it (depending on how impacting the fix would be, and if is is easily merged from v6.0).
Imposed P-Outlet
Re: Imposed P-Outlet
Version 5.0.9
Kind regards,
Ralf
Kind regards,
Ralf
Checking the release notes (or NEWS file) from version 5.0, I see than between v 5.010 and 5.0.11, there is the following:
- Fix shifted index in imposed pressure outlet (GUI).
So if you used the GUI, this was probably the cause of the error, in which case results should be OK with a current 5.0 bug-fix release (5.0.12). I 'll test it some day to make sure.
