Page 2 of 5
Re: "Preprocessing stage required but no mesh is given"
Posted: Sun Oct 27, 2019 2:35 pm
Can you test replacing the bin/cs_case_domain.py with the attached file, then post the output from the script ?
Posted: Mon Oct 28, 2019 12:39 pm
by senartcon
I pasted the script you provided in
/home/.../code_saturne-6.0.0/arch/Linux_x86_64/lib/python3.6/site-packages/code_saturne
which is where the original script was present.
The results have not changed. The attachment has the output directories of both before and after replacing with the script you provided. Am I doing as you intended?
Posted: Mon Oct 28, 2019 4:20 pm
What I am interested in is not the output directory at this stage, but the messages in the terminal from which you ran the code, or the GUI run window contents if run from the GUI (because my modification should simply add additional messages to try to understand where things go wrong).
Posted: Tue Oct 29, 2019 4:59 am
by senartcon
here is the output at the terminal:
                      Code_Saturne
 Version:   6.0
 Path:      /home/anands/Documents/CODE_SATURNE/Code_Saturne/6.0.0/code_saturne-6.0.0/arch/Linux_x86_64
 Result directory:
   /home/anands/Documents/Code_Saturne_Sims/Verify-VolumeHeatSource/Case-2-MiddleStove/RESU/20191028-1656
  Preparing calculation data
  Preprocessing calculation
  File "/home/anands/Documents/CODE_SATURNE/Code_Saturne/6.0.0/code_saturne-6.0.0/arch/Linux_x86_64/bin/code_saturne", line 76, in <module>
    retcode = cs.execute()
  File "/home/anands/Documents/CODE_SATURNE/Code_Saturne/6.0.0/code_saturne-6.0.0/arch/Linux_x86_64/lib/python3.6/site-packages/code_saturne/cs_script.py", line 93, in execute
  File "/home/anands/Documents/CODE_SATURNE/Code_Saturne/6.0.0/code_saturne-6.0.0/arch/Linux_x86_64/lib/python3.6/site-packages/code_saturne/cs_script.py", line 170, in run
  File "/home/anands/Documents/CODE_SATURNE/Code_Saturne/6.0.0/code_saturne-6.0.0/arch/Linux_x86_64/lib/python3.6/site-packages/code_saturne/cs_run.py", line 329, in main
    return run(argv, pkg)[0]
  File "/home/anands/Documents/CODE_SATURNE/Code_Saturne/6.0.0/code_saturne-6.0.0/arch/Linux_x86_64/lib/python3.6/site-packages/code_saturne/cs_run.py", line 317, in run
    stages=stages)
  File "/home/anands/Documents/CODE_SATURNE/Code_Saturne/6.0.0/code_saturne-6.0.0/arch/Linux_x86_64/lib/python3.6/site-packages/code_saturne/cs_case.py", line 2042, in run
    mpiexec_options)
  File "/home/anands/Documents/CODE_SATURNE/Code_Saturne/6.0.0/code_saturne-6.0.0/arch/Linux_x86_64/lib/python3.6/site-packages/code_saturne/cs_case.py", line 1738, in preprocess
    d.preprocess()
  File "/home/anands/Documents/CODE_SATURNE/Code_Saturne/6.0.0/code_saturne-6.0.0/arch/Linux_x86_64/lib/python3.6/site-packages/code_saturne/cs_case_domain.py", line 900, in preprocess
    raise RunCaseError(err_str)
cs_case_domain.RunCaseError: Preprocessing stage required but no mesh is given
I couldnt find much difference except that the error earlier appeared at line 896 (post # 6 in this thread) and this time at line 900.
Anand
Posted: Tue Oct 29, 2019 10:37 am
It seems the problem occurs quite early, and the instrumentation might print empty lines.
I added some additional logging to the attached files. Could you try again with those ?
Posted: Tue Oct 29, 2019 10:46 am
by senartcon
the following is the error report, for the files you have attached:
  File "/home/anands/Documents/CODE_SATURNE/Code_Saturne/6.0.0/code_saturne-6.0.0/arch/Linux_x86_64/lib/python3.6/site-packages/code_saturne/cs_run.py", line 330, in main
  File "/home/anands/Documents/CODE_SATURNE/Code_Saturne/6.0.0/code_saturne-6.0.0/arch/Linux_x86_64/lib/python3.6/site-packages/code_saturne/cs_run.py", line 318, in run
    stages=stages)
    mpiexec_options)
    d.preprocess()
Anand
Posted: Tue Oct 29, 2019 12:08 pm
If you only post the backtrace and not the previous lines, I won't be able to do much.
Posted: Tue Oct 29, 2019 12:09 pm
Posted: Tue Oct 29, 2019 12:16 pm
by senartcon
sorry for the mistake, here is the full listing:
cs_run.py: param = None
read_parameter_file_1 None
                      Code_Saturne
 Version:   6.0
 Result directory:
   /home/anands/Documents/Code_Saturne_Sims/Verify-VolumeHeatSource/Case-2-MiddleStove/RESU/20191029-1518
    stages=stages)
    mpiexec_options)
    d.preprocess()
Posted: Tue Oct 29, 2019 12:49 pm
It seems the parameters file is not passed to the execution script.
Do you start the code with the GUI or directly running the "runcase" file from a terminal ? Could you post your runcase in SCRIPTS ?
