"Preprocessing stage required but no mesh is given"
senartcon
Post by senartcon »
Dear All,
I am facing the problem upon running code_saturne as the title says:
cs_case_domain.RunCaseError: Preprocessing stage required but no mesh is given
although I have ensured that the mesh path is correctly given.
Since after a fresh install of Ubuntu 18.04, Salome and CS 6.0.0 I am facing this issue. To my knowledge there were no issues in installation - please see attached files - setup.txt and install_saturne.log.
For a typical case the run.bat looks normal as i learnt from this forum:
#!/bin/bash
export PATH=/home/anands/Documents/CODE_SATURNE/Code_Saturne/6.0.0/code_saturne-6.0.0/arch/Linux_x86_64/bin:$PATH
# Run command:
\code_saturne run --param MiddleStove.xml --threads-per-task 8
Of the outputs by CS for a typical case, I have attached the 'summary' file output by CS; there is no error file and the listing is not a valid file.
Am I missing some dependencies? Please suggest.
Anand
summary.txt
(5.27 KiB) Downloaded 601 times
install_saturne.log
(2.13 MiB) Downloaded 660 times
setup.txt
(4.35 KiB) Downloaded 624 times
Re: "Preprocessing stage required but no mesh is given"
Could you post the xml file, and (if present in DATA), the cs_user_scripts.py file ?
senartcon
Post by senartcon »
thanks for your reply. Please find attached files you have asked.
I should note that this case was generated and run successfully in CS 5.0.7. Now the xml file has been modified because of saving the case in CS 6.0.0.
Anand
cs_user_scripts.py
(8.27 KiB) Downloaded 641 times
MiddleStove.xml
(10.4 KiB) Downloaded 679 times
senartcon
Post by senartcon »
attached herewith are xml and cs_user_scripts.py for case created using CS 6.0.
Anand
cs_user_scripts.py
(6.45 KiB) Downloaded 633 times
middle_stove.xml
(4.63 KiB) Downloaded 622 times
I do not reproduce your issue using these same files (running on Arch Linux) so I do not really understand where this is coming from. In your case, it seems the cs_user_scripts.py is not useful (it does not contain any additional option) so you can remove it. Can you test again without it ? Also did you vist the mesh page in the GUI before running the case ?
The xml file in your example log (MiddleStove.xml) is different from the one you posted (middle_stove.xml).
Are you sure both have the mesh info ?
senartcon
Post by senartcon »
I removed cs_user_scripts.py but to no avail.
Yes I visited the mesh page in GUI, cleaned the directory listing and populated the meshes again many times, but to no avail.
I have attached mesh files and the latest xml file, if that would help you reproduce any error.
It can be seen that the xml file does have the mesh file names and the path.
I am posting the error Traceback I am getting on the terminal:
  Preparing calculation data
  Preprocessing calculation
  File "/home/anands/Documents/CODE_SATURNE/Code_Saturne/6.0.0/code_saturne-6.0.0/arch/Linux_x86_64/bin/code_saturne", line 76, in <module>
    retcode = cs.execute()
  File "/home/anands/Documents/CODE_SATURNE/Code_Saturne/6.0.0/code_saturne-6.0.0/arch/Linux_x86_64/lib/python3.6/site-packages/code_saturne/cs_script.py", line 93, in execute
  File "/home/anands/Documents/CODE_SATURNE/Code_Saturne/6.0.0/code_saturne-6.0.0/arch/Linux_x86_64/lib/python3.6/site-packages/code_saturne/cs_script.py", line 170, in run
  File "/home/anands/Documents/CODE_SATURNE/Code_Saturne/6.0.0/code_saturne-6.0.0/arch/Linux_x86_64/lib/python3.6/site-packages/code_saturne/cs_run.py", line 329, in main
    return run(argv, pkg)[0]
  File "/home/anands/Documents/CODE_SATURNE/Code_Saturne/6.0.0/code_saturne-6.0.0/arch/Linux_x86_64/lib/python3.6/site-packages/code_saturne/cs_run.py", line 317, in run
    stages=stages)
  File "/home/anands/Documents/CODE_SATURNE/Code_Saturne/6.0.0/code_saturne-6.0.0/arch/Linux_x86_64/lib/python3.6/site-packages/code_saturne/cs_case.py", line 2042, in run
    mpiexec_options)
  File "/home/anands/Documents/CODE_SATURNE/Code_Saturne/6.0.0/code_saturne-6.0.0/arch/Linux_x86_64/lib/python3.6/site-packages/code_saturne/cs_case.py", line 1738, in preprocess
    d.preprocess()
  File "/home/anands/Documents/CODE_SATURNE/Code_Saturne/6.0.0/code_saturne-6.0.0/arch/Linux_x86_64/lib/python3.6/site-packages/code_saturne/cs_case_domain.py", line 896, in preprocess
    raise RunCaseError(err_str)
MiddleStove.zip
(66.27 KiB) Downloaded 618 times
middle_stove.xml
(4.86 KiB) Downloaded 636 times
You files work fine on my system, so I would suspect some installation issue.
One last thing you may try on your current install is to uncheck the "preprocessing only" option in the mesh settings, or switch to "import only", which would produce a "mesh_input" file usable for another run.
Otherwise do you have references to a previous install somewhere in you environment (in PATH, LD_LIBRARY_PATH, PYTHONPATH)... ? or Ubuntu packages of another version of Code_Saturne installed ? This might cause issues. Doing a fresh install in another directory may help.
senartcon
Post by senartcon »
it is unfortunate that the following recommendations did not work
And i went for a fresh ubuntu 18.04 install today and the error still persists!
Are you sure you do not have another code_saturne install in Ubuntu (such as packaged install, installed through Synaptic / apt-get) ?
Otherwise, I will send you some slightly modified version of the Python scripts, with additional instrumentation/logging, so as to understand what is going wrong....
senartcon
Post by senartcon »
yes, I am sure there is no other code_saturne install.
I am trying to install CS on a fresh Ubuntu installation.
Please send the required files. I shall execute as you suggest.
Anand
