Internal wall not detected in code saturne 4.2
sagarcfd
Re: Internal wall not detected in code saturne 4.2
Post by sagarcfd »
Thanks for your reply. I carried out simulation using .xml file and user subroutine given by you on code saturne 4.2. But baffle is not detected. Will you please tell me which version you used and can you share listing file for same.
Hoping for your reply,
Sagar
Luciano Garelli
Post by Luciano Garelli »
Hello Sagar,
I tested with both, CS 4.0 and 4.2. I attach the corresponding RESU directories with the listing files and solutions.
I can not figure what can be the problem..In the listing files the group "8" now it is a boundary face.
RESU.tar.gz
(5.2 MiB) Downloaded 593 times
sagarcfd
Post by sagarcfd »
Hello Luciano,
I could successfully detect thin wall after I used configured Code Saturne 4.0.6 version. Earlier I was using Code Saturne installed through synaptic package manager. I have attached file with steps for installation if someone needs. Thanks for your support.
Sagar
code_saturne_install.doc
code saturne installation
(15 KiB) Downloaded 466 times
Are you using Debian or Ubuntu (or some other Debian-based variants) ?
This issue had appeared on Ubuntu a few years ago, was not reported for a while, and seems to resurface (it is probably related to some specific build or packaging option they use, but I don't know where).
sagarcfd
Post by sagarcfd »
I am using ubuntu 16.04 LTS.
Sagar
