Thanks for your reply. I carried out simulation using .xml file and user subroutine given by you on code saturne 4.2. But baffle is not detected. Will you please tell me which version you used and can you share listing file for same.
Hoping for your reply,
Sagar
Internal wall not detected in code saturne 4.2
Luciano Garelli
Re: Internal wall not detected in code saturne 4.2
Hello Sagar,
I tested with both, CS 4.0 and 4.2. I attach the corresponding RESU directories with the listing files and solutions.
I can not figure what can be the problem..In the listing files the group "8" now it is a boundary face.
- RESU.tar.gz
- (5.2 MiB) Downloaded 573 times
Hello Luciano,
I could successfully detect thin wall after I used configured Code Saturne 4.0.6 version. Earlier I was using Code Saturne installed through synaptic package manager. I have attached file with steps for installation if someone needs. Thanks for your support.
Sagar
Sagar
- code_saturne_install.doc
- code saturne installation
- (15 KiB) Downloaded 447 times
Are you using Debian or Ubuntu (or some other Debian-based variants) ?
This issue had appeared on Ubuntu a few years ago, was not reported for a while, and seems to resurface (it is probably related to some specific build or packaging option they use, but I don't know where).
I am using ubuntu 16.04 LTS.
Sagar
Sagar
