Code Saturne Tutorials and Case Studies
Re: Code Saturne Tutorials and Case Studies
User subroutine examples are available in the "Doxygen" documentation, in this website's documentation section.
Yes, Code_Saturne can simulate gas combustion. I'll see which test cases we might be able to provide.
sdn
Post by sdn »
Thank you, I very much look forward for the test cases.
Sincerely,
Saaddin Nur
Here is one gas combustion test case.
COGZ_D3P.tar.gz
(225.99 KiB) Downloaded 673 times
sdn
Post by sdn »
Thank you very much for the attachment. It is exactly that I need. It would be nice if you can also give the evaporation and condensation case :)
Sincerely,
Saaddin Nur
sdn
Post by sdn »
In the same manner, the "3 disks" tutorial is for conjugate heat transfer.
I'm still trying The 3 disk tutorial to know the conjugate heat transfer mechanism with coupling of code saturne and syrthes.
I've successed running the code saturne and syrthes separately in that tutorial.
But, I found error when I try to run the coupling simulation of code saturne and syrthes in the last step of the tutorial.
Here I attach the relevant file regarding my error simulation.
Hope the problem can be solved soon.
Sincerely,
Saaddin Nur
3disk2D.zip
Here is the project file
(4.43 MiB) Downloaded 554 times
error_report.rar
Here is the error report file of the project
(2.8 KiB) Downloaded 592 times
Could you switch from MED to EnSight output format to check what is wrong here ?
sdn
Post by sdn »
Here I attach my case with Ensight output format setting.
I'm still finding the error the error. Now, no error in syrthes but still error in code saturne.
Hope it can be solved soon,
Sincerely,
Saaddin Nur
error_report_baru.rar
(18.94 KiB) Downloaded 557 times
rev_3disks2D.zip
(4.36 MiB) Downloaded 569 times
Tee crash seems to be due to a "SIGSEGV" (usually produced by accessing an incorrect memory location, such as when a wrong array index or invalid variable is used).
Another user had a very similar issue with Syrthes coupling a few months ago. I don't remember the exact solution, but you should find it in one of the most recent conversations regarding SYRTHES in this forum. Use the "search" feature, it works reasonably well.
