User subroutine examples are available in the "Doxygen" documentation, in this website's documentation section.
Yes, Code_Saturne can simulate gas combustion. I'll see which test cases we might be able to provide.
Code Saturne Tutorials and Case Studies
Re: Code Saturne Tutorials and Case Studies
Thank you, I very much look forward for the test cases.Yes, Code_Saturne can simulate gas combustion. I'll see which test cases we might be able to provide.
Sincerely,
Saaddin Nur
Here is one gas combustion test case.
- COGZ_D3P.tar.gz
- (225.99 KiB) Downloaded 673 times
Thank you very much for the attachment. It is exactly that I need. It would be nice if you can also give the evaporation and condensation caseHello,
Sincerely,
Saaddin Nur
I'm still trying The 3 disk tutorial to know the conjugate heat transfer mechanism with coupling of code saturne and syrthes.In the same manner, the "3 disks" tutorial is for conjugate heat transfer.
I've successed running the code saturne and syrthes separately in that tutorial.
But, I found error when I try to run the coupling simulation of code saturne and syrthes in the last step of the tutorial.
Here I attach the relevant file regarding my error simulation.
Hope the problem can be solved soon.
Sincerely,
Saaddin Nur
- 3disk2D.zip
- Here is the project file
- (4.43 MiB) Downloaded 553 times
- error_report.rar
- Here is the error report file of the project
- (2.8 KiB) Downloaded 591 times
Could you switch from MED to EnSight output format to check what is wrong here ?
Here I attach my case with Ensight output format setting.Hello,
I'm still finding the error the error. Now, no error in syrthes but still error in code saturne.
Hope it can be solved soon,
Sincerely,
Saaddin Nur
- error_report_baru.rar
- (18.94 KiB) Downloaded 556 times
- rev_3disks2D.zip
- (4.36 MiB) Downloaded 568 times
Tee crash seems to be due to a "SIGSEGV" (usually produced by accessing an incorrect memory location, such as when a wrong array index or invalid variable is used).
Another user had a very similar issue with Syrthes coupling a few months ago. I don't remember the exact solution, but you should find it in one of the most recent conversations regarding SYRTHES in this forum. Use the "search" feature, it works reasonably well.
