SYRTHES 4.3 with CS 3.0.7
Re: SYRTHES 4.3 with CS 3.0.7
The first syntax should be OK.
The second one is incorrect (it can be used to execute a script, not source it), so you should remove it.
andrea28
Post by andrea28 »
Dear Yvan,
I still get the "command not found" error when I try to source Syrthes.
I also tried to add
syrthesprofile=/home/.../syrthes4.3.0/arch/3.10.0-327.10.1.el7.x86_64/bin/syrthes.profile
if [ -f $syrthesprofile ] ; then
. $syrthesprofile
fi
to the cshrc file but I get
syrthesprofile=/home/.../syrthes4.3.0/arch/3.10.0-327.10.1.el7.x86_64/bin/syrthes.profile: Command not found.
syrthesprofile: Undefined variable.
Thank you for your time.
Are you sure of your path ?
Has 3 points (...) where I would expect a full (absolute) path. Did you replace the real path by "..." for the purpose of posting to the forum, or did you really use that path ?
andrea28
Post by andrea28 »
No I used the full path.
Where is Syrthes installed on your machine ?
andrea28
Post by andrea28 »
In /syrthes4.3.0/arch/3.10.0-327.10.1.el7.x86_64
Then you need to use:
syrthesprofile=/syrthes4.3.0/arch/3.10.0-327.10.1.el7.x86_64/bin/syrthes.profile
andrea28
Post by andrea28 »
Sorry but the problem persists, looking through the installation files I saw that each log file (post.log,pp.log,...) present these lines
mkdir: missing operand
Try 'mkdir --help' for more information.
But I don't get any error at the end of the installation or in the ERREUR file.
I attached one of the file.
syrthesmed.log
(1.17 KiB) Downloaded 3680 times
I had not noticed before, but you seem to be using a C shell, as you edit .cshrc, and not .bashrc or similar. The syntax for a C shell is different, and I am not sure the Syrthes profile is designed for a C shell. Basically, you need to replace "export" with "setenv", and I am not sure how to source files.
