Creation of mesh groups
deandrade87
Post by deandrade87 »
is it possible to create mesh groups within the fortran part of the code? If not, is there a simple user example that explains how to build a C/fortran binding?
Jacopo
Re: Creation of mesh groups
Hello Jacopo,
No, there is no simple way to do it. Even in C, it is not trivial to do, as you need to change the indexed mesh group descriptions, then change element family numbers in the main cs_mesh_t structure.
Modifying existing group names, or merging groups is very easy to do (cs_user_mesh.c), splitting groups or building groups based on geometry is much more complicated.
In any case, you can use selection criteria with a mix of geometry and group names, but saving this as groups is more difficult.
deandrade87
in the fortran part of the code I have some lists of cells and I would like to postprocess them separately: basically I would like to have a writer for each list. Would it be possible without defining new groups? I fear the answer is no, but you are more expert than me and maybe you have already encountered the problem in the past.
Thank you again for your prompt answer
Jacopo
Hello Jacopo,
Yes, this is actually simple: define one postprocessing mesh for each list.
Then either assign them to a single writer and use "extract blocks" to switch betwen them, or create a separate writer for each list, and associate the mesh to its writer.
