Because of memory limitation, I was forced to subdivide the geometry I use into several domains and then mesh each domain separately.
Because of this I have a question about which option in code_saturne allows joining different meshes through common faces ?!
I found the option "subdivide warped faces" in GUI but I am not sure if this it's the right option.
Thank you in advance.
RC
how to join different meshes
Re: how to join different meshes
No, you need to define mesh joinings.
rezki
Thank you for the answer,
This is actually the aim of my question
Where to find this option for mesh joinings in saturne and how to use it ?!
Regards.
RC
Regards.
RC
The "Face Joining" definition section is just above the "subdivide warped faces" checkbox in thee GUI...
