Saturne4.0.0-rc2 with Syrthes4.3
ffan
Post by ffan »
Dear Code_Saturne users and developers,
I installed Code_Saturne4.0.0-rc2 and Syrthes4.3.0 on Xubuntu12.04LTS (CAELinux2013). Each works fine stand-alone. When coupled for conjugate heat transfer, i.e., running "runcase" with "coupling_parameters.py", it said:
./syrthes: error while loading shared libraries: libple.so.1: cannot open shared object file: No such file or directory
I searched for libple.so,1. The share object is actually available in /usr/local/lib. What does it fail to find it? Thank you.
- ffan
runcase.log
(2.75 KiB) Downloaded 906 times
Re: Saturne4.0.0-rc2 with Syrthes4.3
Is the Syrthes build precompiled or compiled locally ? If One code is compiled for 64 bits and the other for 32, it could explain the issue.
Otherwise, could you run "ldd" on both cs_solver and syrthes executables in the failed run's subdirectories ? Then try again setting:
export LD_LIBRARY_PATH=/usr/local/lib:$LD_LIBRARY_PATH
Or possibly better,
sudo ldconfig
to update the linker's cache.
