How to stop the code ?
pleblanc86
Post by pleblanc86 »
I have not found anything on the forum, so I am asking you the question :
How to stop the code when we use the criteria set by the user.
I tried with csexit() function without succes.
Does exists specific function for this ?
Thank you for you help
Paul
Brian Angel
Re: How to stop the code ?
Post by Brian Angel »
Which version of CS are you using and are you using the GUI for running your simulations?
Brian Angel.
csexit should work, but it is a "violent" stop (it will kill the postprocessing output, and more).
To stop cleanly (from cs_user_extra_operations.f90), set ntmabs = ntcabs
To stop cleanly from a terminal or script, use the "control_file" (search the user pdf fr details).
pleblanc86
Thank you for your reply. I think will use the control_file
Thanks you for your help
Paul
Jacques Fontaine
Post by Jacques Fontaine »
It will be more convenient to set ntmabs = ntcabs when your residual is small enough (do this in cs_user_extra_operations.f90).
