Dear Saturne users,
I have a mesh that the preprocessor says:
Criterion 3: Least-Squares Gradient Quality:
Number of bad cells detected: 43737 --> 2 %
Criteria 6: User Specific Tag:
Number of bad cells detected: 122473 --> 7 %
Is it possible to visualize and locate these bad cells via ParaVis/ParaView? Thanks.
- ffan
Visualize and locate the bad cells
Re: Visualize and locate the bad cells
If you did not program it, the user criteria is arbitrary (it is an example), so you can ignore it.
To visualize quality criteria, run the code in "mesh quality check" mode, and visualize the output in ParaView or EnSight.
Thanks Yvan.
- ffan
- ffan
