Head Loss Region Syntax
Vance-Turner
I am trying to define a cylindrical head loss region (to approximate an actuator disk). The disk has some thickness in x; but is cylindrical in y and z (the axis of the cylinder is in the x-direction). The dependence on y would be something like: y <= sqrt(1-z^2); but how do I specify this in code-saturne? Is this even possible? I've searched for such syntax; but found none.
Brian Angel
Re: Head Loss Region Syntax
Hello Vance,
You should be able to use the source terms subroutine "cs_user_source_terms.f90" in the SRC/REFERENCE directory to define the head losses for the zone that represents the actuator disc.
Brian Angel.
Brian Angel.
Jacques Fontaine
Vance,
You may use the subroutine uskpdc (uskpdc.f90) to impose head losses. You also can use ustvnv (cs_user_source_terms.f90) as said Brian to impose momentum source terms.
