Dear friends,
I would appreciate your suggestions.
My Linux system is Fedora 17/32 bit
My saturne version is 3.0
My Salome version is 7.2.0 installed from 32 bit universal binaries
Configure was run with option --with-salome=/home/salome/salome/Salome-V7_2_0-LGPL-i686
Salome seems to run OK with runAppli.
Code saturne installs with no errors
However, when giving
./code_saturne salome
system answers
SALOME not available in this installation.
Do I miss something here?
Note: code_saturne is in /home/saturne
Thanking everybody in advance
Nick
code_saturne 3.0 and Salome 7.2.0
Re: code_saturne 3.0 and Salome 7.2.0
No, this should work, but as we try to autodetect SALOME for several build types, we may have missed some combinations...
Are you using Code_Saturne 3.0.0 or 3.0.1 ? There was a fix in 3.0.1 relative to detection of some SALOME builds, and there is a second one in upcoming 3.0.2 (not released yet, but you can get the fix at http://code-saturne.org/viewvc/saturne/ ... _salome.m4; you then need to run ./sbin/bootstrap from to top source directory, which requires having autotools and such installed...).
You may also post your config.log here for additional details.
nppetro
Thank you indeed for your reply.
My cs version is actually 3.0.1. Sorry, I missed to report it correctly.
edit:
[got the fix into the m4 dir in the source folder
Then from the top I run /sbin/bootstrap
Then configure etc. make make install. However, no luck SALOME is not there]
Since we are now on to it, and there seems to exist a small bug, I also noticed the following:
(a)
I have installed med 3.0.6 using the install_saturn.py script up to the point where saturn configuration starts. Installation dir was /home/medlib/opt1.0/med-3.0.6
However, and when starting the saturne installation and despite telling the configurator that --with-med=/home/medlib ... etc. MED headers could not be found. Yet, they do exist in /home/medlib/opt1.0/med-3.0.6/include
The reason that I used the .py script was that MED instructions were in French, which I do not handle well.
and (b)
My system does have cgns and blas installed by its package manager. However, saturne installer seems that it cannot find them. This happens even if I tell the configurator the dir paths of these packages.
edit: (b) was corrected. I had not installed the devel packages therefore headers were missing.
edit: I assume that (a) might be part of the same problem.
Thank you once more for your time
Nick
edit:
(a)
and (b)
Nick
If you post your config.log file, I should be able to get more information on why some package detections failed and what to do about them.
For SALOME, your bin/package.py (in the build directory) may be useful also.
nppetro
Here is what I finally did after giving it some trial and error:
(A) For SALOME and CodeSaturne (cs)
1. I untarred the cs tarball thus creating a clean source directory
2. I went to m4 directory and replaced cs_salome.m4 with the latest version as you suggested
3. From source home I run ./sbin/bootstrap
4. Then I run configure with the --prefix and --with-salome choices
5. The executable of cs was created and was able to start salome giving the command code_saturne salome
(B) For med library
It is definite that med library should be put in the same directory where the bin of code_saturne would be placed. It seems to me that file cs_med.m4 cannot find it, if it is located elsewhere.
Thank you once more.
Nick
(B) For med library
Nick
Thanks for the feedback. There is still no reason --with-med=<path_to_external_med> should not work (it works on all other machines I have tested on so far), so I would still be interested in the config.log file for the case where MED was not detected correctly, if you still have that.
