I run a simulation from 50000 to 300000 iterations (time step number) with 57 probes, and I set "nthist" at one. Simulation is at the 117000 iteration number but only the first ten iterations are printed in tmp files (from 50001 to 50010).
Is there a solution (with "nhist") to print results regularly in probes_files ?!
Regards.
Rezki
print in probes_files at each time step ?
JamesMcNaughton
Re: print in probes_files at each time step ?
You can type the following to print to the listing every 100 time steps.
By default it will do the first 10 and then every 1/4 of the calculation.
Also I think the file is rewritten not appended to, so don't do this too often for big calculations or you'll waste a lot of time.
nthsav = 100Also I think the file is rewritten not appended to, so don't do this too often for big calculations or you'll waste a lot of time.
rezki
OK thanks for your help.
So I think that I can change this default value in "caltri" and print results every 1/10 of the calculation for example.
Regards.
Rezki
nthdef = (ntmabs-ntpabs)/4
nthdef = (ntmabs-ntpabs)/10Rezki
JamesMcNaughton
You can change it in usini1, anywhere in the usipes subroutine. So a good place is the line below where nthist is.
But yes if you wanted to override the default then change in caltri.
