turbine modelling
stage75
Re: turbine modelling
THank you a lot James,
In my case I don't use GUI, I use the command line, and in the case of coupling I have two DATA (DATA.1 and DATA.2)!.
JamesMcNaughton
Do it once for DATA.1 and once for DATA.2 then
stage75
I copied the whole directory RESTART.07161632 from the RESU directory to the DATA.1 and DATA.2 directories then I changed my ntmabs and time step then I run "./runcase" I obtenied this error! (I tried to erase all the white spaces between caracteres)
Code :
and
Do you have an idea
Code :
File "./runcase", line 95
THERMOCHEMISTRY_DATA=
SyntaxError: invalid syntaxCode: Select all
PARAM= PARAMETERS
NameError: name 'PARAMETERS' is not definedDo you have an idea
JamesMcNaughton
This seems strange as you should not have changed the runcase file.
But I think the line should read:
Maybe the white space is important?
And the restart should be like, for example: DATA.1/RESTART/suiava. So try renaming your RESTART.07161632 to RESTART
THERMOCHEMISTRY_DATA = NoneAnd the restart should be like, for example: DATA.1/RESTART/suiava. So try renaming your RESTART.07161632 to RESTART
stage75
I copied the whole directory RESTART.07161632 from the RESU directory to the DATA.1 and DATA.2 directories then I changed RESTART.07161632 to RESTART.
I try, as you said, DATA.1/RESTART/suiava. I have this message (bash: cd: RESTART/suiava: N'est pas un dossier), The principle is to restart the simulation by the commande . / runcase like the first simulation or not?
Thank's
Thank's
JamesMcNaughton
It looks like it is looking for the folder:
when it should be looking for the folder
(this contains the files suiava and suiavx).
Have hard coded something in runcase that might be an issue? Does it say suiava anywhere in the file? Otherwise you'll have to ask someone more knowledgeable than myself as I never had issues like this when using the coupling.
To restart you type ./runcase as before (set isuite=1 in usiini1).
James
DATA.1/RESTART/suiavaCode: Select all
DATA.1/RESTARTHave hard coded something in runcase that might be an issue? Does it say suiava anywhere in the file? Otherwise you'll have to ask someone more knowledgeable than myself as I never had issues like this when using the coupling.
James
stage75
Thank you veryyy much James, I think I've found, I had to add the number of current "ntmabs" to the old (ntmabs = 50 +50 for exemple) (I've deleted the old)
Thank you james you helped me a lot (you and yvan and others)
Other question, Is there an option to save my simulation at every moment that I want instead to restart several times?
Thank's a loooot
Thank's a loooot
JamesMcNaughton
Glad it is working now..
To print the post-processing (ensight / paraview) files change ntchr=X with X the frequency of time-steps to print at.
stage75
I view with Salome, I don't know too well paraview.
Thank you very much James.
In the following I would like to make biphasic (basin contains half water and half air), I'll see how it works if I can and I would ask questions on the forum
Thank's a lot,
For Yvan, I see If you have not yet had time to look the prob I think it's good it's not worth it, I confirm tomorrow on the forum is that the results are OK!
Thank's for all
Thank's a lot,
Thank's for all
