I installed successfully code saturne -2.1.4 by using the command ./install_saturne ..
In gui , i am unable to import the boundary conditions from mesh_input (preprocessor listing)..
can u please help me out of this problem...
thanks & regards
theju
code saturne -2.1.4
Re: code saturne -2.1.4
You should use the preprocess.log file, not mesh_input to import boundary conditions (this will hopefully change in future versions, and mesh_input will then indeed be the file to use, but this is not the case yet).
Guest
Helloo,
In code-saturne-2.1.4 , log file is not generating after check mesh.
Please help me out of this...
thank you.
thank you.
Guest
Helloo,
I installed two versions 2.0.2 & 2.1.4 , I already got 2.0.2 wizard from CAE linux DVD . how can i create one more wizard for 2.1.4???
Code_Saturne has no concept of wizards, so I assume this is a CAE linux functionnality. The CAE Linux forum may be of more help for this question.
Guest
Helloo,
thank you.
thank you.
Are you sure ?
In version 2.0, the log file appears in a window, and you may choose to save it where you want.
In version 2.1, the file is saved automatically, in a fixed path (under RESU/check_mesh/check_mesh.log)
Are you sure ?
