follow of boundary condition in a file
Alexandre Guilloux
Post by Alexandre Guilloux »
Hi
I have a question concerning the follow of boundary condition write in the subroutine usclim.f90.
My simulation is a room with a heater.
The temperature of the heater depend on the temperature in a cell volume (which is calculate in the subroutine usproj.f90)
This is my code in the subroutine usclim.f90
CALL GETFBR('x>=4.9 and x<=5.1 and y>=-2 and y<=0 and z>=0 and z<=1',NLELT,LSTELT)
    !Température de consigne de la pièce
    TempCon = 25.d0
    If (Temppiece < TempCon) then
        !Radiateur allume
      TempRadia = 70.d0
        Do ilelt = 1, nlelt
             ifac = lstelt(ilelt)
             ITYPFB(IFAC,IPHAS)=IPAROI
          rcodcl(ifac,isca(1),1) = TempRadia
        etatradia = 1.d0
     else
      !     !Radiateur égal à la
température de la pièce
      Do ilelt = 1, nlelt
              TempRadia = Temppiece
TempRadia
      etatradia = 0.d0
    endif
Is it possible to write a file in the subroutine usclim.f90? I want the variable etatradia to each time step.
Re: follow of boundary condition in a file
If you simply want a trace of the on/off status, yes, you may easily write a file from usclim. Just be careful to open the file at the first time step only (or to close it and re-open it in append mode), and to open it only on one processor if you are running in parallel (the examples in usproj.f90 may be adapted to what you want to do in usclim.f90).
Alexandre Guilloux
Thank for the rapidity of your answer
I forgot the test on one processor, now it's work correctly.
Alexandre
