OT: Postprocessing Syrthes
Kathi Blum
Post by Kathi Blum »
Good morning,
i tried the tools "syrthes2med223" and "syrthes2ensight" to convert the syrthesresults. I use Paraview 3.8.0 and Salome 5.1.3. Paraview loads the ".case" file but shows only a thin line. With Salome I can see the nodes (in Post_Pro), but the nodal results are wrong on some places.
Could you give me a hint, please?
regards,
Kathi
Re: OT: Postprocessing Syrthes
There may have a bug in "syrthes2ensight" (see the following thread: https://code-saturne.info/products/code-saturne/forums/general-usage/335742402 ) A patched version is in this thread at: https://code-saturne.info/products/code-saturne/forums/general-usage/335742402/307514245/syrthes2ensight.c
Regarding Syrthes2med, MED 2.2 is obsolete, so you should use syrthes2med23 instead.
Best regards,   Yvan
Kathi Blum
it still doesn't work, even with the "new" syrthes2ensight. What else can be wrong? I attached the example files. Here is the output:
caelinux@arbeit:~/Desktop/case/SCHNIAK/RESU/RESU_SYR.11301428$ syrthes2ensight -g geoms.syr ens_geom
===============================================================                          SYRTHES2ENSIGHT                          ===============================================================                                                         I. Rupp
Traitement de la geometrie uniquement
--> nom du fichier geom : ens_geom.ensight.geom
--> nom du fichier case : ens_geom.ensight.case
MAILLAGE SYRTHES :
Dimension                    3
Dimension des elements       3
Nombre de noeuds             43119
Nombre d'elements            26308
Nombre de noeuds par element 10
Fin de la lecture des coordonnees des noeuds Syrthes
Fin de la lecture de la connectivite Syrthes
Ecriture des 43119 noeuds au format Ensight
Ecriture des 26308 elements au format Ensight
Nombre de faces de reference  4 =      508
Nombre de faces de reference  5 =     6322
Nombre de faces de reference  6 =      796 ===============================================================                      SYRTHES2ENSIGHT                                               Fin du traitement
error_paraview-tar.bz2
(2.15 MiB) Downloaded 365 times
Jérôme Ferrari
Post by Jérôme Ferrari »
I tested your ensight file, it opens fine in paraview 3.9 and in ensight 9.0.2.
I tried to create med (using syrthes2med23) and it seemed ok in salome 5.1.3: you have 2 cylinders, 1 time step and temperature ranging from 26.32 to 27.35.
cylinders.med.gz
(1.68 MiB) Downloaded 386 times
Kathi Blum
Thanks for testing Jérôme,
i'd tested it with ParaView 3.8.1; so I wait until 3.9 is ready.
Thanks again!
Tom
