Thanks for the info, seems to be working now. However, when checking the listing file, I saw this:
** FORTRAN WORK ARRAYS MEMORY USED
191164 INTEGERS NEEDED: MAXIMUM REACHED IN TRIDIM
4576320 REALS NEEDED: MAXIMUM REACHED IN MEMNAV
Where can I correct this? Thanks.
No residuals tracking but calculation keeps running
Re: No residuals tracking but calculation keeps running
It is an information, not something to be corrected.
If you wish to adjust the memory usage more precisely than the automatic procedure, you have to use the GUI, heading "Memory Management".
In a follow up to the residuals tracking I am trying to print these at each time step using the DERVAR array. DERVAR(3) - DERVAR(7) is listing the derived residual for u, v, w, k, e / w respectively but DERVAR(2) is not the pressure, although it is close to that in the listing. Is the pressure residual stored in a separate array or is it manipulated in a manner before being outputted to the listing file?
Hello James,
Actually what we call "derive" in Code_Saturne in somewhat complicated... and may be a remaining of development verification.
For all the convected variables (so everything except pressure), the derive stands for the following expression and may be used as a criterion to see the convergence of a steady calculation (though a true residual would perhaps be better).
Hope this helps !
David
ps : to understand the calculation of the derive, you can have a look at the ecrlis.f90 subroutine ("preduv.f90 + resolp.f90" for the pressure)
On the contrary, for the pressure, the derive stands for a ratio between the divergence of "predicted velocity field + Rhie & Chow filter" and the divergence of "predicted velocity field". So, I strongly advise you to not take into account this number!dervar(ipp) = || [u(n+1) - u(n)] / "time step" ||² / "total volume" with ||.|| being the L2 norm
As you can see, this is completely different... and quite complexdervar(ipp) = || div(rho.u*) + RC ||² / || div(rho.u*) || with ||.|| being the L2 norm and RC the Rhie & Chow filter
Hope this helps !
David
Hi David,
Just for information, does the "derive" variable for Pressure have a physical meaning?
Hi Axel,
I would answer no. This is definitely numerical information that gives the "weighting" of the Rhie & Chow filter. It actually has nothing to do we a so-called "derive"; it's more something for developers...
David
David
