Thanks Yvan for your response,
The alternate route seems promising for now.
Can you please inform me to process of mesh input preprocessing in local machine and upload the same to Cluster. I will follow the same for time being.
Sofen
CGNS Mesh reading error in Curta Cluster
sofenkumarjena
sofenkumarjena
Re: CGNS Mesh reading error in Curta Cluster
Thanks Yuvn,
It would be wonderful, if you can inform the process of generating preprocessor in local machine and use the same in cluster.
This will be really helpful.
With Regards
Sofen
With Regards
Sofen
This is available using the GUI. Just run in preprocessing mode only first, then use the existing mesh_input on your cluster.
