I would like to perform matrix operations inside a fortran user subroutine, with code_saturne v6. I need Lapack.
I read a post in this forum discussing how to install code_saturne v2 with Lapack.
What is the procedure you reccomend with v6?
Daniele
Lapack with v6
Re: Lapack with v6
Iy you use Lapack only in user subroutines, you can simply add the required compile and link flags in a cs_user_scripts.py file (under DATA), in the domain.compile_cflags, domain.compile_cxxflags, and domain.compile_libs entries.
Re: Lapack with v6
I am not very good in compiling stuff, could you please help me further: what do I have to specify exactly for domain.compile_...? The location of the Lapack libraries etc?
Thanks a lot for your time.
Daniele
Daniele
Re: Lapack with v6
On a system where Lapack is installed under /usr, simply use
On a system where it is installed on, for example /opt/lapack, adapt this:
You might then have other errors due to dependencies, and need to add other libriaries (i.E. BLAS) depending on your system.
domain.compile_cflags = None
domain.compile_cxxflags = None
domain.compile_fcflags = None
domain.compile_libs = -llapack
domain.compile_cflags = -I/opt/lapack
domain.compile_libs = "-L/opt/lapack -llapack"Best regards,
Re: Lapack with v6
Thank you very much Yvan.
I managed to properly link Lapack!
Daniele
Daniele
