Problem about 'Residual', 'Drift', 'CFL number'.
JeremyA
Re: Problem about 'Residual', 'Drift', 'CFL number'.
Post by JeremyA »
I resume this discussion because I am pretty interesting in the answer Yvan
Jérémy
JeremyA
Post by JeremyA »
Up
With Code_Saturne, how can we be sure that the calculation is converged ?
Especially for a transient calculation, which parameter we should check in listing file for convergence of each time step ?
Could you explain each parameter in the listing file : Rhs norm; Norm Residual, Drift, Time residual ?
Thank you
Jeremy
Ionut G
Post by Ionut G »
Hi all!
After some searching on this forum and the functions from code_saturne, I found that norm.residual is the residual I should check in order to see if the simulation is converging or not.
From the file ecrlis.f90, the drift or derive residual is defined as DRIFT=((x_n-x_(n-1) )^2*cell volume)/(time step).
Also from the file ecrlis.f90, the norm residual is defined as norm=sqrt(cs_gres(ncel,volume,w1,w1)),
where cs_gres is the global residual of 2 extensive vectors and is defined as 1/sum(vol) . sum(X.Y/vol)
and w1=((x_n-x_(n-1) )*cell volume)/(time step).
Am I correct? Could someone confirm this?
Best Regards,
Ionut
Ionut G
Post by Ionut G »
Ionut G wrote: Wed Feb 12, 2020 11:36 am Hi all!
Best Regards,
Ionut
Can anyone confirm this? Or, if it is wrong, point me in the right direction?
Thanks in advance,
Ionut
Yes, this seems correct.
Ionut G
Post by Ionut G »
Thank you very much Yvan!
Ionut
