Mesh displacement and déplacement fields
So_nuc
Post by So_nuc »
WIthin an ALE Simulation in Code_Saturne (v5.0.8), both "Mesh displacement" and "déplacement" are displayed in the postprocessing med file but they contain actually the same values (since they are the same field).
How is it possible to remove one of them by means of the cs_user_parameters.f90 file for example (without the GUI) ?
Thank you in advance.
So_nuc
Re: Mesh displacement and déplacement fields
This is a minor bug (a missing cleanup). One of the 2 instances is related directly to the postprocessing output, and cannot be deactivated using simply user subroutines, but the other is probably stored as a field (check setup.log for the list of fields), so that one should can have its output turned off either in the GUI (I think) or setting the "post_vis" keyword for that field to 0.
