Fortran pointer of rank 1 requested for values of field "velocity", which have rank 2
AHIC
Post by AHIC »
hello,
I got the error message:
../../../../src/code_saturne-4.0.8/src/base/cs_field.c:987: Fatal error.
which have rank 2.
How can i fix it please ?
Re: Fortran pointer of rank 1 requested for values of field "velocity", which have rank 2
Are you using user subroutines ?
AHIC
Post by AHIC »
Yes, and i have already check if i have the good syntax for the call of the velocity field in my subroutine file.
If i have understood correctly:
field_get_val_s for scalar
field_get_val_v for vector
are there an conflict between the id fields ?
subroutine 1:
call field_get_val_s(ivarfl(isca(1)), x_var) ! champ X
call field_get_val_s(ivarfl(isca(2)), y_var) ! champ Y
call field_get_val_s(ivarfl(isca(3)), z_var) ! champ Z
call field_get_val_v(ivarfl(iu), cvar_vel)
subroutine 2:
call field_get_val_s(icrom, crom) ! champ w
call field_get_val_s(ivarfl(ivart), cvar_vart)
call field_get_val_s(ivarfl(isca(1)), x_var) ! champ x
call field_get_val_s(ivarfl(isca(2)), y_var) ! champ y
call field_get_val_s(ivarfl(isca(3)), z_var) ! champ z
call field_get_val_s(iprpfl(itempc), pro_tempc)
Did you check the definition/declaration of cvar_vel ? It should have dimension(:,:) and not dimension(:).
AHIC
Post by AHIC »
It's seems to be correct:
double precision, dimension(:,:), pointer :: cvar_vel
Do you have a backtrace ? The error is probably due to some wrong value of ivarfl(j) where j might match an array not used here.
Using the "get_by_name" varients of the field access functions would be safer here (but I am not sure they were present in Code_Saturne v4.0).
AHIC
Post by AHIC »
When i try to remove this line, i always have the same error.
which have rank 2.
I do not have enough information to work with to provide relevant suggestions.
AHIC
Post by AHIC »
In attachements file: compile and error log file.
When i remove the problematic subroutine file (cs user extra operation),
the compilation works.
best regards,
error.txt
(781 Bytes) Downloaded 305 times
compile.log
(21.56 KiB) Downloaded 302 times
This is still not sufficient information to work with.
