I am trying to add some librairies at the compilation by using cs_user_script.py file.
In this file, I tried to replace
domain.compile_libs = None
by
domain.compile_libs = "-lmedcoupling"
But it does not seem to work.
What is the correct syntax to add librairies in this file ?
Is that the simplest way to do this ?
Thank you.
Seb
Adding librairies at the compilation
Re: Adding librairies at the compilation
Could you post your error message ? You syntax seems ok, but may be missing other options (for example, you may need a library search path using "-L" and possible also "-rpath" instead of simply -lmedcoupling).
I only modify domain.compile_libs in cs_user_script.py, nothing else.
I get the following errors during compilation :
cs_case_domain.RunCaseError: Compile or link error.
undefined reference to « ParaMEDMEM::DataArrayDouble::New() »
It works if I add the librairies directly in compilation options of Code_Saturne (for all users) but not if I use this user script. This is not a library problem. Maybe I use this script badly since the link is not done.
Seb
Seb
