Another 2 questions.
1) What is the scheme for the solver in equation parameters? (first choice before centred,upwind etc. in the GUI)
2) I am trying to run a heated channel flow case with low Reynolds number models (v2_BL_v2/k, Rij-epsilon EBRSM) and they do not converge. I run the case with high-Reynolds model (k-epsilon with 2scale wall function) and the results are fine for y+>30. They Retau is 1020, half channel width is 1.Any suggestions?
Costas
Code_Saturne_Automatic scheme and Low_Re_models Convergece
Re: Code_Saturne_Automatic scheme and Low_Re_models Convergece
For the scheme, do you mean what is the automatic choice ? I think it is centered for most variables, and upwind for turbulence variables such as k and epsilon, but I recommend checking in the listing and setup.log files.
Could you post the info recommended in the forum rules for the case which does not work ?
Hi Costas,
I guess you are running steady-state simulations. Which algorithm are you using for pressure-velocity coupling? In my experience SIMPLE is quite unstable when using low-Reynolds models, even in basic planar channel flows. Switching to SIMPLEC (with a Courant value around 4.0, or even lower if necessary) improved the stability a lot.
Andrea
Andrea
Thank you all for your replies. I actually used SIMPLEC for the pressure-velocity coupling. I found out that the Rij-espilon EBRSM requires GGDH hypothesis for the scalar temperature. For the rest of the models apparently there was an issue with my mesh which I sorted by splitting the geometry into half and using geometric progression (expansion ratio) in Salome mesh. I also changed the reference value that I initialise turbulence to higher (i.e 30 m/s) and it worked.
But I will check also the listing file and my courant number.
Costas.
Costas.
Hi
What kind of scheme it is used for Pressure in the 'Scheme' tab from the 'Equation Parameters' menu?
I attached a picture too. showing the issue that I have.
Thank you,
Ionut
Thank you,
Ionut
This is not an "issue". The pressure is not a convected variable, but handled in the velocity-pressure algorithm. You can check the theory guide if you need more details.
