Deformation and Big displacement
Paul Brss
Post by Paul Brss »
I'm interested in FSI simulations with big displacement of the structure. I thought of 3 ways to do it and I could'nt find any answer on the following questions:
- Is it possible to realize a coupling with 3 codes: Saturne (for the moving domain close to the structure)/Saturne (the far field domain)/Aster (for the structure) ?
- Could Saturne realize vertical sliding mesh (I know it's possible with rotating mesh) ? And if yes, how does he treat the mesh at the boundaries ? And again, is it possible to couple with aster in this case ?
- Can saturne remesh under some conditions (mesh quality for example) during the simulation ?
There might be another option to realize big displacement with a structure coupling with Saturne ?
If anyone has an idea !
Paul
Re: Deformation and Big displacement
The coupling with 3 codes should be possible id code_aster is only coupled to one Code_Saturne domain (though it's not been tried before). To couple one code_aster instance with two Code_Saturne would require significant changes in the coupling infrastructure (which is in serious need of a rewrite, but this is not a short term issue).
Using a sliding instead of rotating mesh would require only minor changes in the Code_Saturne sources (but cannot yet be done using user functions only). The coupling involves boundary conditions only, so it is explicit in terms of time-stepping.
As the code does not include remeshing, this could be handled by measuring mesh quality criteria at each time step, and using checkpoint/restart on new meshes. The code cannot currently handle interpolating to a new mesh upon restart, but this is something we have pretty precise ideas on, and could be done with quite minor changes (and a bit of testing).
So basically, if you are comfortable with coding and willing to do minor development and a bit of testing, I can happily guide you through this. If you need something "out of the box", then the feature set is not quite ready yet.
Paul Brss
Post by Paul Brss »
First of all, thank you for your very clear answer !
In my case, only one Code_saturne domain will be coupled with aster. And the same one will be coupled with another code_saturne domain.
Do you have any documentations on Saturne/Saturne coupling ? I only found some presentation of RANS/LES hybrid mesh simulations.
I'll keep you in touch when I make a choice. I need to talk to my superior first.
Paul
Unfortunately, there is not much documentation with code/code coupling. At least I can point you to the relevant files if you decide to work on this...
Paul Brss
Post by Paul Brss »
So I'm interesting in Saturne/Saturne coupling. I'm going to start without aster for now.
Is it based on Chimere method ?
So, can you tell me which files are relevant ? I didn't find much on "user" and "theory" pdf.
And can you advise me on some scientific works/papers useful, if it's not too much to ask ?
Thank you in advance,
Paul
Sorry for not answering earlier.
You can check the cs_user_coupling.c user function to define a coupling (as well as create 2 coupled cases with "code_saturne create -c domain1 -c domain2" type syntax).
The boundary condition coupling functions are at the C/Fortran interface, and utility functions defined mostly in src/base/cs_sat_coupling.c (with the location aspects in libple, but you should not need to change those). Most of the coupling logic (the part you may need to adapt) is in the src/base/csc*.f90 functions.
It may also be useful to "grep" for the "imobil" keyword in the Fortran sources, as this is related to mobile meshes (rotor-stator in the current case, adaptable to large deformations). Actually I recommend starting with this.
Actually the following link is old but still mostly relevant: [url][http://cfd.mace.manchester.ac.uk/twiki/ ... upling/url]
I am not aware of papers that would provide any detailed information useful for this (there may be some internal reports, but I'm not sure about those; I'll try to check).
Paul Brss
Post by Paul Brss »
Thanks for your answer. I apologize for answering that late (Happy new year, by the way).
I'll take a look at your advice the coming weeks.
Did you manage to check for internal reports by chance ?
Paul
And happy new year.
Not yet, but I should probably see some of the code_aster developers in a meeting next week, so I'll ask them the question.
Paul Brss
Post by Paul Brss »
First of all, do you have some news on some documentations about Code/code coupling ?
I would need some information about how the interpolation are made from one domain to the other (on the theory aspect).
I checked the sources codes as you adviced but it's still unclear.
On the other hand, I would need some help on how to run the simulation.
I run code_saturne create -s name -c domain1 -c domain2, so I have two case, a new "runcase' file, etc...
Now my question is where to put the cs_user_coupling.c file:
- In the SRC directory of both domain1 and domain2 ?
- In the SRC directory of just one domain ? And which one ?
- In a new SRC directory created where the domain1 and domain2 cases are ?
In addition, I have some trouble to filled the cs_sat_coupling_define fonction.
Eventually, I've got some error :
Error parsing expression:
all
Erreur de syntaxe, probablement due à des opérandes mal placés
Please find attached the listing, error and *.log files of both domain.
Many thanks,
Paul
dynamic.zip
(14.17 KiB) Downloaded 582 times
static.zip
(9.42 KiB) Downloaded 588 times
A copy of cs_user_coupling.c much be in each domain (with selection criteria adjusted to each domain).
The syntax for selection criteria is detailed in the user documentation. Functions are postfixed by"[]" (possibly with arguments between the brackets). So "all[]" is correct but "all" is not (unless a group named "all" is present, in which case it should be allowed (I need to check there is no parse error).
