Installation code_Saturne
Sherko
Post by Sherko »
Hi ...
If any one can help me ... I want to know how I can install code_Saturne 4.3.3 automatically by using (install_saturne.py).
I am trying to install code_saturne, I installed Ubuntu 16.04 and Salome ver. 7.3.0 , every things are well. I downloaded code_saturne 4.3.3, and I made new folder named code_saturne, I extract the package of saturne. I entered in the folder code_saturne 4.3.3 and made folder saturne_bulid, and I want to do the installation automatically.
When I wrote .. /code_saturne-4.3.3$./install_saturne.py
The installation is not work and the program recommend me to run it from separate directory, and its first time to me, I do not know how to make it?
Sherko
Luciano Garelli
Re: Installation code_Saturne
Post by Luciano Garelli »
Did you check the "Code Saturne version 4.0.0 installation guide" ? I never used the python script, I always use the configure, make and make install like in the example in the secc 6.9 of the guide.
http://code-saturne.org/cms/sites/defau ... ll-4.0.pdf
Sherko
Post by Sherko »
Hi ...
Thank you very much for your advice, I work on it but the installation not going well.
This is some of things that a present on the screen of my pc after
/configure
..... looks running good
and when
/make
sherko@sherko-LIFEBOOK-T731:~/Code_Saturne/code_saturne-4.3.3$ make
make all-recursive
make[1]: Entering directory '/home/sherko/Code_Saturne/code_saturne-4.3.3'
Making all in .
make[2]: Entering directory '/home/sherko/Code_Saturne/code_saturne-4.3.3'
rm -f bin/code_saturne bin/code_saturne.tmp
/bin/mkdir -p bin
srcdir=''; \
test -f ./bin/code_saturne.in || srcdir=./; \
sed -e 's|@PYTHON[@]|/usr/bin/python|g' -e 's|@pkgpythondir[@]|/usr/local/lib/python2.7/dist-packages/code_saturne|g' -e 's|@relocatable[@]|no|g' ${srcdir}bin/code_saturne.in >bin/code_saturne.tmp
mv bin/code_saturne.tmp bin/code_saturne
rm -f bin/cs_package.py bin/cs_package.py.tmp
/bin/mkdir -p bin
srcdir=''; \
test -f ./bin/cs_package.py.in || srcdir=./; \
sed -e 's|@prefix[@]|/usr/local|g' -e 's|@exec_prefix[@]|/usr/local|g' -e 's|@bindir[@]|/usr/local/bin|g' -e 's|@includedir[@]|/usr/local/include|g' -e 's|@pkgincludedir[@]|/usr/local/include/code_saturne|g' -e 's|@libdir[@]|/usr/local/lib|g' -e 's|@libexecdir[@]|/usr/local/libexec|g' -e 's|@pkglibexecdir[@]|/usr/local/libexec/code_saturne|g' -e 's|@pythondir[@]|/usr/local/lib/python2.7/dist-packages|g' -e 's|@pkgpythondir[@]|/usr/local/lib/python2.7/dist-packages/code_saturne|g' -e 's|@localedir[@]|/usr/local/share/locale|g' -e 's|@datarootdir[@]|/usr/local/share|g' -e 's|@datadir[@]|/usr/local/share|g' -e 's|@pkgdatadir[@]|/usr/local/share/code_saturne|g' -e 's|@docdir[@]|/usr/local/share/doc/code_saturne|g' -e 's|@pdfdir[@]|/usr/local/share/doc/code_saturne|g' -e 's|@sysconfdir[@]|/usr/local/etc|g' -e 's|@PACKAGE_NAME[@]|code_saturne|g' -e 's|@PACKAGE_TARNAME[@]|code_saturne|g' -e 's|@PACKAGE_VERSION[@]|4.3.3|g' -e 's|@PACKAGE_STRING[@]|code_saturne 4.3.3|g' -e 's|@PACKAGE_BUGREPORT[@]|saturne-support@edf.fr|g' -e 's|@PACKAGE_URL[@]|http://code-saturne.org|g' -e 's|@cs_src_revision[@]|4.3.3|g' -e 's|@cs_version[@]|4.3|g' -e 's|@cs_version_full[@]|4.3.3|g' -e 's|@cs_version_short[@]|4.3|g' -e 's|@SALOME_KERNEL[@]|/usr|g' -e 's|@SALOMEENVCMD[@]||g' ${srcdir}bin/cs_package.py.in >bin/cs_package.py.tmp
mv bin/cs_package.py.tmp bin/cs_package.py
make[2]: Leaving directory '/home/sherko/Code_Saturne/code_saturne-4.3.3'
Making all in libple
make[2]: Entering directory '/home/sherko/Code_Saturne/code_saturne-4.3.3/libple'
make all-recursive
make[3]: Entering directory '/home/sherko/Code_Saturne/code_saturne-4.3.3/libple'
Making all in src
make[4]: Entering directory '/home/sherko/Code_Saturne/code_saturne-4.3.3/libple/src'
make[4]: Nothing to be done for 'all'.
make[4]: Leaving directory '/home/sherko/Code_Saturne/code_saturne-4.3.3/libple/src'
Making all in tests
make[4]: Entering directory '/home/sherko/Code_Saturne/code_saturne-4.3.3/libple/tests'
make[4]: Leaving directory '/home/sherko/Code_Saturne/code_saturne-4.3.3/libple/tests'
Making all in doc
make[4]: Entering directory '/home/sherko/Code_Saturne/code_saturne-4.3.3/libple/doc'
Making all in doxygen
make[5]: Entering directory '/home/sherko/Code_Saturne/code_saturne-4.3.3/libple/doc/doxygen'
make[5]: Nothing to be done for 'all'.
make[5]: Leaving directory '/home/sherko/Code_Saturne/code_saturne-4.3.3/libple/doc/doxygen'
make[5]: Entering directory '/home/sherko/Code_Saturne/code_saturne-4.3.3/libple/doc'
make[5]: Nothing to be done for 'all-am'.
This is first time for me trying to install code Saturne
Please follow the forum usage recommendations and post at least your "config.log".
Sherko
Post by Sherko »
Hello
Dear Yvan, thank you for your notes. Today I downloaded Saturne 5 and I am trying to installed it, but the same errors. The problem that I do not have the scales to connect (link) between the libraries to install the code, in other hand, I am really need to install the code.
Thank you
config.log
(252.56 KiB) Downloaded 837 times
The configure script should be run from a separate directory. The first or second page of the installation documentation explains how to do this.
Running configure in the sources directory pollutes them, so I recommend starting from a new archive (.tar.gz) first.
Also, version 4.3 is obsolete (and not maintained anymore), so version 5.0 is recommended.
Sherko
Post by Sherko »
Thank you very much, I read the document more than 5 times (it is recommended to build the code in a separate directory from the sources). I do not know how to make separate directory and install from it (if you can not reply me because of the policy of the site its o.k to me).
Just create a directory side by side, for example:
tar xvzf code-saturne-5.0.4.tar.gz
mkdir -p saturne_build/opt
cd saturne_build/opt
../../code-saaturne-5.0.4/configure --prefix=$HOME/Code_Saturne/arch/opt
To replace your previous "configure", then:
make
make install
Luciano Garelli
In your config.log you just run ./configure, but you have to link CS with third-party libraries like hdf5, Med, MPI, etc.
This is my configure line. Most of the are get from salome.
$ ../saturne-git/configure --prefix=/home/lg/Code_Saturne.git/saturne-git.opt --enable-openmp
--with-mpi-include=/usr/include/mpich-x86_64
--with-mpi-lib=/usr/lib64/mpich/lib CC=mpicc CXX=mpicxx --with-metis=/usr/lib64
--with-med-include=/home/lg/salome/Salome-V8_2_0-univ/tools/Medfichier-321/include
--with-med-lib=/home/lg/salome/Salome-V8_2_0-univ/tools/Medfichier-321/lib
--with-libxml2=/home/lg/salome/Salome-V8_2_0-univ/prerequisites/Libxml2-290
--with-hdf5=/home/lg/salome/Salome-V8_2_0-univ/prerequisites/Hdf5-1814
--with-scotch-lib=/usr/lib64 --with-scotch-include=/usr/include
--with-cgns=/home/lg/salome/Salome-V8_2_0-univ/prerequisites/Cgnslib-3134
Sherko
Post by Sherko »
Thanks for the commands. I did as you wrote to me, but it still with many errors.
Best regards.
config 26-9.log
(252.79 KiB) Downloaded 763 times
