Convergence
Convergence
I am doing a quick calculation of a steady laminar flow over a plate with code saturne.
I want to show that the boundary layer thickness is equal to d=4,92.x/[(Rex)^1/2]
In the same time I want to show that the thermal boundary layer thickness is : d_T=d*Pr^(1/3)
I just did a rectange 10*20*100 cm, (with the top face as a symmetry), the fluid is air ;
the inflow velocity is 1m/s, inflow temperature 40°C;
the wall temperature is 20°C;
100 iterations (0.01 pseudo step time)
But my results are wrong : I find a temperature going to 321 °C, the velocity does not show any boundary layer..
1) Does anyone has an idea why this is not converging ?
2) What is the main criteria (in the listing file) of convergence (I saw both Norm. Residual, Derive, and Rhs Norm) ?
Thank you,
P.S. : my Norm residual for velocity pressure and temp is approximately 10e-3, whereas my derive is of 10e-3 for the velocity, 10e-1 for pressure and 10e3 for temperature (seems really high).
Thank you,
Re: Convergence
What type of mesh are you using ? Could you post the log file types listed in the forum recommendations section ?
Derive is the main convergence indicator, but there is no automatic convergence test, and plotting probes is a recommended way to check the convergence behavior.
Re: Convergence
The mesh is a CGNS (2.5) file produced using Hypermesh, code saturne check mesh is telling me that the type is "MIXED"
extract from the check_mesh :
Zone 1: "cfd_model"; type "Unstructured"
85753 vertices; 419557 cells
(cartesian coordinates, "RealDouble" precision, unit "Null")
Section 1: "Fluid";
(indices 1 to 419557, type "MIXED")
Section 2: "Inflow";
(indices 419558 to 421853, type "MIXED")
Section 3: "Outflow";
(indices 421854 to 424149, type "MIXED")
Section 4: "Wall";
(indices 424150 to 457943, type "MIXED")
Section 5: "Symmetry";
(indices 457944 to 480373, type "MIXED")
Section 1: "Fluid";
Section 4: "Wall";
Re: Convergence
This only provides me limited information. Could you please also post the info which is listed in the forum usage guidelines ?
Re: Convergence
Ok sorry,
My version of C_S is the 4.0
I do not have any file called compile.log (is it strange ?)
I send you the mesh preprocessor.log and listing if you need anything more tell me
Thank you
Thank you
- plaque_plane.zip
- (6.22 MiB) Downloaded 385 times
Re: Convergence
I don't see anything obviously wrong with your time step/CFL values, but as long as you only post part of the recommended information, I can't guess at if/where you may have an error in our setup.
Re: Convergence
I'm sorry I just saw :
Could you tell me what file is missing ?
But as I told you I have neither compile.log, nor error files.In case the recommendations above are not enough, providing the following details when posting to this forum will help others answer:
• version of Code_Saturne,
•the compile.log,
•the listing and preprocessor.log (or listpre for old versions),
•in parallel, the error_n* files if they are present.
If it's possible:
• user sources and xml file,
• meshes.
Re: Convergence
How about the setup (xml and/or user subroutines) ?
Re: Convergence
Hello Yvan,Yvan Fournier wrote:Hello,
How to plot probes with values of derive in the listing? In order to see if it converges.
Thanks very much
Kinds Regards
XING Jian
Re: Convergence
As Yvan mention, you could use monitoring (probe) points inserted through the GUI (Calculation Control -> Output control -> monitoring points) in different spatial location in order to check the time/iteration evolution of your variables (pressure, velocity, etc), but not the derive indicator. If you want to check the derive of any of the variable you can parse the listing file during the simulation with this command for example for the pressure
Or after/during the simulation with
which will cut columns
tail -f listing | grep "c Pressure"
cat listing | grep "c Pressure" | cut -c52-64
