Hi all,
i'm trying to import like a boundary field (i.e yplus) the boundary thermal flux (input_thermal_flux in paraview or thermal_flux in CS gui) using .c subroutines. However, as i checked, the field is not defined when user_postprocess is called and so i just can't import it. How can i read such field inside my function?
Thank you
Andrea
Importing thermal_flux values
Re: Importing thermal_flux values
Which version of the code are you using ? Are you also using the GUI ? Depending on postprocessing options, the matching field is created or not (see src/addflf.f90 for the definition logic if you need more details).
I'm using CS 4.0 builded on linux Ubuntu 16.04 and on Win7. I can't find addflf.f90, instead i have addfld.f90 that i suppose is the subroutine you wanted me to look. Yes i always use GUI to setup the postprocessing surface output. How can i call the f90 function to create such thermal_flux field before my postprocessing cs_user_postprocess.c subroutine call?
Thank you
Andrea
Thank you
Andrea
Sorry, you used the right file (my typo), but this is the right file only for more recent versions. In version 4.0, the file to check was fldini.f90, and the field is created if ineedy is set (in cs_user_parameters.f90, in usipsu), or if a field named "boundary_forces" located on boundary faces is defined in cs_user_parameters.c.
from the file you suggested me :
i prepared a simulation with some printf in the cs_user_postprocess.c to better understand the fields and their values. This is the output:
based on what you said i imported the boundary_forces field however such values are not comparable to the "input_thermal_flux" field .
boundary forces values :
min -3.2e+03 max = -1.8e+02
Any idea on what is wrong ?
Thank you
! Additional fields
325 !------------------
326
327 ! Fields used to save postprocessing data
328
329 itycat = FIELD_INTENSIVE + FIELD_PROPERTY
330 ityloc = 3 ! boundary faces
331
332 ! If postprocessing of boundary temperature or boundary layer Nusselt required
333 if (ipstdv(ipsttb).gt.0 .or. ipstdv(ipstnu).gt.0) then
334 call field_create('tplus', itycat, ityloc, idim1, ilved, inoprv, iflid)
335 call field_create('tstar', itycat, ityloc, idim1, ilved, inoprv, iflid)
336 endif
337
338 ilved = .true.
339
340 if (ineedf.eq.1) then
341 call field_create('boundary_forces', itycat, ityloc, idim3, ilved, inoprv, &
342 iforbr)
343 endif
344
345 if (ipstdv(ipstyp).ne.0) then
346 call field_create('yplus', itycat, ityloc, idim1, ilved, inoprv, iyplbr)
347 endif
field number = 20
field list =
Velocity
Pressure
k
omega
TempC
Density
Boundary Density
LamVisc
TurbVisc
CourantNb
FourierNb
total_pressure
Local Time Step
dttens
inner_mass_flux
boundary_mass_flux
tplus
tstar
boundary_forces
Yplus
input_thermal_flux (from paraview) :fmin= -0.000166 fmean 0.000001 fmax= 0.000196
Thank you
I tryed again leaving only, as surface postprocessing: Yplus, Dimensionless Thermal flux, Boundary temperature, Thermal flux, Tplus . And the field boundary_forces doesn't exist anymore, so i suppore is related only to stress/force efforts not to thermal flux.
field number= 19
field list =
Velocity
Pressure
k
omega
TempC
Density
Boundary Density
LamVisc
TurbVisc
CourantNb
FourierNb
total_pressure
Local Time Step
dttens
inner_mass_flux
boundary_mass_flux
tplus
tstar
Yplus
Here again, I may have answered a bit fast and lost track of whether you required boundary forces and boundary thermal fluxes...
A minor remark: no need for user postprocessing to check which files exist, since the setup.log file lists all fields which are defined (at least all fields defined before the time loop, which is the recommended practice).
In any case, extra fields are created in fldini.f90 and addfld.f90 at different stages. Main resolved variables in fldvar.f90, main properties in fldprp.f90 (and specific physical modeals have their own extra initializations). But checking again, the "input-thermal_flux" output is not a field, but a locally evaluated expression (see dvvpst.f90). This should be generalized in the future as "evaluators" (similar to fields but with local/temporary lifecycle), but wok on this has not started yet (so it will be post-5.0).
So to compute (locally) the boundary thermal flux, you need to call the "post_boundary_thermal_flux" routine from the post_util module. There is no C version in 4.0 (in 5.0, there are both the legacy Fortran version and a new C version).
