dc electric arc
manar
dc electric arc
Post by manar »
Hello every one , I am new with code-saturne , I am working on dc electric arc and went through many posts but still confused about how to set-up an electric arc case since there is not enough tutorial for the windows GUI , any help will be appreciated :mrgreen:
Re: dc electric arc
There is no tutorial for electric arcs. I need to check if I can provide a test case from the validation suite, so I'll keep you informed.
manar
Re: dc electric arc
Post by manar »
Hello Yvan
thanks a lot , :P
Re: dc electric arc
Which version of the code are you using ? I can send you a test case tomorrow, but need to know whether you need it in V4.0 or V4.3 type setup.
manar
Re: dc electric arc
Post by manar »
Hello Yvan Fournier ,
I am using Code_Saturne version 4.0.5 , Salome 7.6.0 for pre and post processing
laptop core i5 , Windows 10 -64 bit
Manar
Re: dc electric arc
Here is an example case.
PFENDER_CASE1.tar.gz
(1.43 MiB) Downloaded 945 times
manar
Re: dc electric arc
Post by manar »
Hello Yvan
thanks foe the model, however I found some difficulties running it , although it seems ready to be run , I also could find a version of SIMAIL foe windows in order to study the mesh , any suggestion :mrgreen:
Re: dc electric arc
SIMAIL is an old tool, and I'm not sure there is a Windows version.
To study the mesh, simply run Code_Saturne in "check mesh mode" and postprocess the output.
manar
Re: dc electric arc
Post by manar »
thanks a lot Yvan
now regarding the implementation of the example case attached above , when I press the the start calculation button there no response at all , I don't even get a listing to figure out the error , what could be the reasons behind that ?
Re: dc electric arc
This seems to be the same issue many people have mostly on Windows, and which we hoped was solved in version 4.0.5 (but it seems not).
It is a bug related to Qt/Python, but you can work around this bug by directy running the "runcase.bat" script in the case's SCRIPT directory.
