jgd23
Post by jgd23 »
I try to reinstall Syrthes with the modified "/usr/bin/mpicc" instead of "mpicc" for the wrapperC in the setup.ini file.
I have new errors. Syrthes in stand alone mode doesn't work.
ar xv /home/julien/Syrthes/syrthes4.3.0/arch/Linux_x86_64/lib/libsyrthes_mpi.a mainsyrthes.o
Makefile:15: recipe for target 'exe' failed
SYRTHES4 home directory: /home/julien/Syrthes/syrthes4.3.0/arch/Linux_x86_64
MPI home directory: /usr
Prepare SYRTHES execution directory
Building the executable file syrthes..
ar: /home/julien/Syrthes/syrthes4.3.0/arch/Linux_x86_64/lib/libsyrthes_mpi.a: Aucun fichier ou dossier de ce type
make: *** [exe] Error 9
Error during the compilation stage
Error during building syrthes executable.
Error during the prepration step (errno: 2
Stop Syrthes execution.
Maybe some new informations for you? Do you think that I have to reinstall everything now?
Julien
gbenefice
Post by gbenefice »
Hello
I try to install Salome 7.6.0, Code Saturne 4.0.5 and Syrthes 4.3 via Oracle VM Virtual Box 5.1.0 on Ubuntu 16.04 LTS. So I have very carefully read your discussion.
The installation of Salome and CS is OK and I was able to launch the tutorial 1 (Simplified nuclear vessel with salome and without).
My problem is the installation and the utilization of Syrthes.
Like the Syrthes web site is offline, I have downloaded Syrthes on the Ubuntu website (http://packages.ubuntu.com/wily/syrthes). My setup.ini file is as an attachement. I have the following message:
--> No such file or directory /home/benefice/Logiciels/Syrthes/syrthes-4.3.0-dfsg1/src//syrthes-gui/exe.linux-x86_64
function report
NO file ERREUR.log
Before using SYRTHES, each user must source
the /home/benefice/Logiciels/Syrthes/syrthes-4.3.0-dfsg1/arch/Linux_x86_64/bin/syrthes.profile file before using the code.
The easiest way is to put the following lines in each of the users
 '.profile' or '.bashrc' (depending on the shell)
syrthesprofile=/home/benefice/Logiciels/Syrthes/syrthes-4.3.0-dfsg1/arch/Linux_x86_64/bin/syrthes.profile
#(adjust path to your system)
if [ -f $syrthesprofile ] ; then
  . $syrthesprofile
fi
Warning : installation of some composants failed
Check log files for more information....
I have checked all log files and the installation is OK except for the syrthes-gui. It would seem that the Syrthes package is not complete. The exe.linux-x86_64 directory is missing in syrthes-4.3.0-dfsg1/src/syrthes-gui.
When I launch syrthe-gui, I have the following message:
/home/benefice/Logiciels/Syrthes/syrthes-4.3.0-dfsg1/arch/Linux_x86_64/bin/syrthes.gui: ligne 3: /home/benefice/Logiciels/Syrthes/syrthes-4.3.0-dfsg1/arch/Linux_x86_64/lib/syrthes-GUI_exe/SyrthesMain: Aucun fichier ou dossier de ce type
Could you tell me how download the syrhtes-gui executable files ? Thanks
Julien, I think that it is necessary to put "mpicc" for the wrapperC in the setup.ini file. If you use "/usr/bin/mpicc", the program researchs the mpicc file in the /usr/bin/usr/bin directory and no in /usr/bin.
Best regard
Guillaume
setup.ini
(4.48 KiB) Downloaded 714 times
The Web page to download Syrthes is now: https://www.edf.fr/en/the-edf-group/wor ... ciel=10818 (just press "cancel" for the login prompt which seems due to a bug in the shiny new EDF website).
jgd23
Post by jgd23 »
Thank you both of you.
I have created a new VM ubuntu 15.10. I have installed CS4.2.1 and Syrthes4.3, both can run in serial and parallel.
I have again a problem to couple the 2 codes. I use the same setup files for CS and Syrthes that Yvan help me to write.
Coupling execution between:
o Code_Saturne [1 domain(s)];
o SYRTHES [1 domain(s)];
Code_Saturne
Version: 4.2
Path: /home/julien/Code_Saturne/4.2.1/code_saturne-4.2.1/arch/Linux_x86_64
Result directory:
/home/julien/test_CS42/4-2Ddisks/case1/RESU_COUPLING/20160727-1120
Preparing calculation data
SYRTHES4 home directory: /home/julien/syrthes43/syrthes4.3.0/arch/Linux_x86_64
***** SYRTHES compilation and link completed *****
Single processor SYRTHES simulation.
Preprocessing calculation
SyrthesCase summary:
Name = solid
Data file = solid-coupling.syd
Update Data file = True
Do preprocessing = True
Debug = False
Case dir. = /home/julien/test_CS42/4-2Ddisks/case1/solid
Execution dir. = /home/julien/test_CS42/4-2Ddisks/case1/RESU_COUPLING/20160727-1120/solid
Data dir. = /home/julien/test_CS42/4-2Ddisks/case1/solid
Source dir. = /home/julien/test_CS42/4-2Ddisks/case1/solid
Post dir. = /home/julien/test_CS42/4-2Ddisks/case1/RESU_COUPLING/20160727-1120/solid/POST
Conduction mesh dir. = /home/julien/test_CS42/4-2Ddisks/mesh/solid
Conduction mesh name = 3rond2d.syr
Total num. of processes = 1
Logfile name = syrthes.log
Echo = True
Parallel run = False
SyrthesParam summary
Param file name = solid-coupling.syd
Conduction mesh name = /home/julien/test_CS42/4-2Ddisks/mesh/solid/3rond2d.syr
Radiation mesh name = None
Result prefix. = resu2
Restart = False
Coupling = True
Interpreted functions = False
Start SYRTHES preprocessing
Updating the mesh file name..
-> OK
Starting calculation
with errorcode 1.
mpiexec.openmpi noticed that process rank 0 with PID 23114 on node julien-VirtualBox exited on signal 11 (Segmentation fault).
solver script exited with status 139.
Either Code_Saturne or SYRTHES may have failed.
Check Code_Saturne log (listing) and SYRTHES log (syrthes.log)
Saving calculation results
Post-processing..
.syrthes (.res) --> ensight...
--> /home/julien/syrthes43/syrthes4.3.0/arch/Linux_x86_64/bin/syrthes4ensight -m "/home/julien/test_CS42/4-2Ddisks/mesh/solid/3rond2d.syr" -r "/home/julien/test_CS42/4-2Ddisks/case1/RESU_COUPLING/20160727-1120/solid/resu2.res" -o "resu2"
File "/home/julien/Code_Saturne/4.2.1/code_saturne-4.2.1/arch/Linux_x86_64/bin/code_saturne", line 76, in <module>
retcode = cs.execute()
File "/home/julien/Code_Saturne/4.2.1/code_saturne-4.2.1/arch/Linux_x86_64/lib/python2.7/site-packages/code_saturne/cs_script.py", line 89, in execute
File "/home/julien/Code_Saturne/4.2.1/code_saturne-4.2.1/arch/Linux_x86_64/lib/python2.7/site-packages/code_saturne/cs_script.py", line 152, in run
File "/home/julien/Code_Saturne/4.2.1/code_saturne-4.2.1/arch/Linux_x86_64/lib/python2.7/site-packages/code_saturne/cs_run.py", line 363, in main
return run(argv, pkg)[0]
File "/home/julien/Code_Saturne/4.2.1/code_saturne-4.2.1/arch/Linux_x86_64/lib/python2.7/site-packages/code_saturne/cs_run.py", line 351, in run
stages=stages)
File "/home/julien/Code_Saturne/4.2.1/code_saturne-4.2.1/arch/Linux_x86_64/lib/python2.7/site-packages/code_saturne/cs_case.py", line 1868, in run
self.save_results()
File "/home/julien/Code_Saturne/4.2.1/code_saturne-4.2.1/arch/Linux_x86_64/lib/python2.7/site-packages/code_saturne/cs_case.p Coupling execution between:
Code_Saturne
Version: 4.2
Result directory:
Name = solid
Debug = False
Echo = True
Restart = False
Coupling = True
-> OK
with errorcode 1.
Post-processing..
stages=stages)
self.save_results()
File "/home/julien/Code_Saturne/4.2.1/code_saturne-4.2.1/arch/Linux_x86_64/lib/python2.7/site-packages/code_saturne/cs_case.py", line 1725, in save_results
d.copy_results()
File "/home/julien/Code_Saturne/4.2.1/code_saturne-4.2.1/arch/Linux_x86_64/lib/python2.7/site-packages/code_saturne/cs_case_domain.py", line 1245, in copy_results
raise RunCaseError(err_str)
cs_case_domain.RunCaseError:
Error during SYRTHES postprocessing
d.copy_results()
Julien
syrthes.log
(7.33 KiB) Downloaded 667 times
listing.txt
(28.71 KiB) Downloaded 727 times
This seems to be the exact same issue as you encountered before...
I'll try to run more debugging tools with Syrthes some day, but I am already very busy with Code_Saturne development and support, and if I don't manage to reproduce the exact same issue, debugging will be difficult. I first need to check whether I upgraded my Ubuntu VM to 16.04 or am still on 15.10 (I don't use it much, my main home OS is Arch Linux, and work OSs are Debian). If I do still have it, I'll try to reproduce the issue... But probably not this week...
Otherwise, if anybody else who knows how to use a debugger is willing to help you first, they are welcome...
Finally, an interesting test would be to try the same case with Syrthess alone (replacing the coupled boundary conditions with heat exchange coefficients, with a user-defined coefficeint and external temperature). If you reproduce the crash on Syrthes alone, debugging will be much easier.
jgd23
Post by jgd23 »
I will try to reinstall everything on debian 8.5.0 (amd64).
I don't know how to define a user defined coefficient heat transfert with syrthes for the test (user subroutine?). If you have an user subroutine I can compile it and test it.
I try only with constant values Syrthes in stand alone mode and it was working.
Julien
jgd23
Post by jgd23 »
I am on debian 8.5.0 now. I succeed to install salome 7.6.0, CS4.0.5, I can also launch code_saturne salome. It works on serial and parallel config.
I have difficulties with Syrthes4.3 for installing med (use=yes install=yes) and scotch (use=yes install=yes). Without installing and using these (using med308 from salome library) I can go to the end of the installation and launch the GUI but can't work with the mesh (due to wrong format of med308 -> syrthes 4.3 uses med307).
Where is the problem to install Syrthes?
Unzip med-3.0.7
* Installation MED *
cat: med.log: Aucun fichier ou dossier de ce type
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking how to create a ustar tar archive... gnutar
checking whether to compile using MPI... no
checking for style of include used by make... GNU
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking dependency style of gcc... gcc3
checking for gcc option to accept ISO C99... -std=gnu99
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
configure: Can't find a parallel version of HDF.
checking how to run the C preprocessor... gcc -std=gnu99 -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking absolute name of <H5public.h>... checking H5public.h usability... yes
checking H5public.h presence... yes
checking for H5public.h... yes
///home/julien/syrthes43/syrthes4.3.0/extern-libraries/opt/hdf5-1.8.14/arch/Linux_x86_64/include/H5public.h
checking absolute name of <H5Ipublic.h>... checking H5Ipublic.h usability... yes
checking H5Ipublic.h presence... yes
checking for H5Ipublic.h... yes
///home/julien/syrthes43/syrthes4.3.0/extern-libraries/opt/hdf5-1.8.14/arch/Linux_x86_64/include/H5Ipublic.h
checking for H5open in -lhdf5... no
configure: error: either use HDF5HOME env. var. or --with-hdf5=<path>
make: *** No rule to make target 'install'. Arrêt.
Error during make install of med-3.0.7
Julien
setup.ini
(4.4 KiB) Downloaded 674 times
To avoid those issues, tell Syrthes to use MED and HDF5, but not to install them: use the PATH=, to point either to SALOME's versions, or to the ones installed for Code_Saturne (if they are differrent from SALOME, you have the choice).
jgd23
Post by jgd23 »
Ok it seems to work better, Syrthes works in serial and parallel but I can't postprocess in ensight format, only med
I use for Hdf5 med and scotch the library of Salome 7.6.0
I try the coupled case. I think that's it's a new error (goog news).
julien@debian:~/test_couplage/4-2Ddisks/case1$ ./runcase
Code_Saturne is running
Version: 4.0
Path: /home/julien/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64
Result directory:
/home/julien/test_couplage/4-2Ddisks/case1/RESU_COUPLING/20160728-1552
Name = solid
Debug = False
Case dir. = /home/julien/test_couplage/4-2Ddisks/case1/solid
Execution dir. = /home/julien/test_couplage/4-2Ddisks/case1/RESU_COUPLING/20160728-1552/solid
Data dir. = /home/julien/test_couplage/4-2Ddisks/case1/RESU_COUPLING/20160728-1552/solid
Source dir. = /home/julien/test_couplage/4-2Ddisks/case1/RESU_COUPLING/20160728-1552/solid/src
Post dir. = /home/julien/test_couplage/4-2Ddisks/case1/RESU_COUPLING/20160728-1552/solid/POST
Conduction mesh dir. = /home/julien/test_couplage/4-2Ddisks/mesh/solid
Echo = True
Conduction mesh name = /home/julien/test_couplage/4-2Ddisks/mesh/solid/3rond2d.syr
Restart = False
Coupling = True
-> OK
Error in preprocessing stage.
Post-processing..
.syrthes --> med..
--> /home/julien/syrthes43/syrthes4.3.0/arch/Linux_x86_64/bin/syrthes4med30 -m "/home/julien/test_couplage/4-2Ddisks/mesh/solid/3rond2d.syr" -r "/home/julien/test_couplage/4-2Ddisks/case1/RESU_COUPLING/20160728-1552/solid/resu2.res" -o "resu2.med"
File "/home/julien/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64/bin/code_saturne", line 76, in <module>
File "/home/julien/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64/lib/python2.7/site-packages/code_saturne/cs_script.py", line 88, in execute
File "/home/julien/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64/lib/python2.7/site-packages/code_saturne/cs_script.py", line 150, in run
File "/home/julien/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64/lib/python2.7/site-packages/code_saturne/cs_run.py", line 304, in main
save_results=save_results)
File "/home/julien/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64/lib/python2.7/site-packages/code_saturne/cs_case.py", line 1779, in run
self.save_results()
File "/home/julien/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64/lib/python2.7/site-packages/code_saturne/cs_case.py", line 1694, in save_results
d.copy_results()
File "/home/julien/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64/lib/python2.7/site-packages/code_saturne/cs_case_domain.py", line 1200, in copy_results
Julien
setup.ini
(4.4 KiB) Downloaded 661 times
syrthes.log
(133 Bytes) Downloaded 638 times
Your syrthes.log states: Unable to open file /home/julien/test_couplage/4-2Ddisks/case1/RESU_COUPLING/20160728-1552/solid/resu2.res
Before I forge, I send you a simple patch, attached here (I'll let you add that to the Syrthes sources and recompile), to fix issues at the end of the calculation.
But the first error seems to occur during the preprocessing stage :
So I recommend checking that first (on the Code_Saturne side, probably a non-updated runcase or a missing mesh path in the GUI)
syrthes.c
(45.43 KiB) Downloaded 665 times
