I try now the solution of Oliveira77 in the same post.
I create a text file named CS_salome.sh
#!/bin/bash
source /home/julien/salome/appli_V7_6_0/env.d/envProducts.sh
export LD_PRELOAD=$LD_PRELOAD:/usr/lib/x86_64-linux-gnu/libgfortran.so.3.0.0
//home/julien/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64/bin/code_saturne salome
exit 0
I execute this. It launch CFD study in salome.
I have a new error when I check mesh or when I try to compute
/home/julien/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64/libexec/code_saturne/cs_solver was built without XML support,
so parameter file "cs_cmd" may not be loaded.
Can you help me with this please?
Julien
You need to install the libxml2-dev (or similarly-named) package on your Linux distribution, and re-run the Code_Saturne installation process.
Thank you again
I try to install every packages of libxml that I found on the synaptic, rerun code saturne installation and same errors occurs when I check the mesh. I try to launch code saturne salome without the script CS_salome.sh -> I have the xml error and with the script -> I have the gfortran_1.4 error
I try to build code saturne with required version of libxml2-2.9.2 and specify the path in the set up file of code saturne. Run installation of code saturne without error. But same problem occurs when I want to check the mesh. I try to launch code saturne salome without the script CS_salome.sh -> I have the xml error and with the script -> I have the gfortran_1.4 error
Other ideas?
Julien
Thank you again
Other ideas?
Julien
Mistake, I mean
I try to launch code saturne salome without the script CS_salome.sh -> I have the gfortran_1.4 error and with the script -> I have the xml error
sorry
sorry
When I try code saturne in stand alone mode, I don't have any error for the mesh checking. But I can't run calculation
my terminal:
julien@julien-VirtualBox:~/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64/bin$ ./code_saturne gui
File "/home/julien/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64/lib/python2.7/site-packages/code_saturne/Pages/BatchRunningView.py", line 684, in slotNProcs
self.jmdl.updateBatchFile('run_nprocs')
File "/home/julien/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64/lib/python2.7/site-packages/code_saturne/Pages/BatchRunningModel.py", line 733, in updateBatchFile
self.updateBatchEnvVars()
File "/home/julien/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64/lib/python2.7/site-packages/code_saturne/Pages/BatchRunningModel.py", line 644, in updateBatchEnvVars
batch_lines = self.case['runcase'].lines
AttributeError: 'NoneType' object has no attribute 'lines'
File "/home/julien/Code_Saturne/4.0.5/code_saturne-4.0.5/arch/Linux_x86_64/lib/python2.7/site-packages/code_saturne/Pages/BatchRunningView.py", line 730, in slotBatchRunning
os.chdir(self.case['scripts_path'])
OSError: [Errno 2] Aucun fichier ou dossier de ce type: ''
Julien
my terminal:
Julien
Could you try running SCRIPTS/runcase directly ?
Sorry but how can I do that? You talk about Code saturne sand alone?
Julien
Julien
Did you manage to create a new case, or do you have the crash before ? If you have rhe crash immediately, I recommend reocing the previous install and reinstalling (stand-alone).
I create a new case. Load the mesh, check the mesh (I can't record the check mesh log). I use a check mesh log created with salome to apply BC. I configure the case, I save the xml file and try to compute and I have the error that told you in the previous post.
Julien
Julien
Once you have saved the case, your case directory structure should include a file named "runcase" in the SCRIPTS case subdirectory. Could you try to run it directly (i.e. in a terminal or through a file manager) ? Otherwise, what do you have in the SCRIPTS directory ?
