Mass flow balance issue
Posted: Wed Apr 29, 2015 10:41 am
Hello everybody,
I am working on Code Saturne 2.0.6
I have a mass flow balance issue in a simple case. My mesh is hexahedral and regular. I put an inlet condition for a number of boundary faces on the up left of the domain and an outlet condition for an identical number of boundary faces on the down right of the domain (see associated picture cas.jpg, color what you see is velocity).
The surface inlet and oulet are the same. In the user subroutine usproj, I determine the total inlet and outlet flux by using values of density an velocity of the associated boundary cells (iel= ifabor(ifac) )
See usproj : Flux Integration over ifac of :
flux1=rtp(iel,iu(1))*propce(iel,ipproc(irom(1)))*surfbo(1,ifac)
flux2=rtp(iel,iv(1))*propce(iel,ipproc(irom(1)))*surfbo(2,ifac)
flux3=rtp(iel,iw(1))*propce(iel,ipproc(irom(1)))*surfbo(3,ifac)
It is strange that the total flux obtained for inlet and outlet is different :
from the listing at iteration 5 (line 1491 and 1492) :
usproj - Flux_total = 18.098588275678861 (flux_total is actualy outlet flux)
usproj - Flux_entree1 = 21.228373686915845 (flux_entree1 is actualy inlet flux)
Or in the mass flow semms to be correct at iteration 5 :
** BOUNDARY MASS FLOW INFORMATION
Phase : 1
Boundary type Code Nb faces Mass flow
Inlet 2 420 -0.212000000E+02
Smooth wall 5 43488 0.310910794E-17
Rough wall 6 0 0.000000000E+00
Symmetry 4 0 0.000000000E+00
Free outlet 3 420 0.212000000E+02
Undefined 1 0 0.000000000E+00
Is the integration over associated boundary cells (ifabor(ifac)) correct ? How could you explain these differences ?
Thank you for your help
Meskine
Phase : 1
Meskine
