| integer | nmodmx |
| | number of specific physics
| integer(c_int), dimension(:), pointer, save | ippmod |
| | global indicator for speciphic physics By default, all the indicators ippmod(i.....) are initialized to -1, which means that no specific physics is activated.
| integer | iphpar |
| | ippmod(iphpar) is a global indicator for the specific physics:
| integer | icod3p |
| | pointer for specific physics
| integer | islfm |
| | pointer to specify steady laminar flamelet approach
| integer | icoebu |
| | pointer to specify Eddy Break Up pre-mixed flame with indicator ippmod(icoebu)
| integer | icolwc |
| | pointer to specify Libby-Williams pre-mixed flame withy indicator ippmod(icolwc)
| integer | ieljou |
| | pointer to specify Joule effect module (Laplace forces not taken into account) with indicator ippmod(ieljou):
| integer | ielarc |
| | pointer to specify Electric arcs module (Joule effect and Laplace forces) with indicator ippmod(ielarc):
| integer | iccoal |
| | pointer to specify multi-coals and multi-classes pulverised coal combustion with indicator ippmod(iccoal). The number of different coals must be inferior or equal to ncharm = 3. The number of particle size classes nclpch(icha) for the coal icha, must be inferior or equal to ncpcmx = 10.
| integer | icompf |
| | pointer to specify compressible module with indicator ippmod(icompf)
| integer | iatmos |
| | pointer to specify atmospheric flow module with indicator ippmod(iatmos)
| integer | iaeros |
| | pointer to specify cooling towers module with indicator ippmod(iaeros)
| integer | igmix |
| | pointer to specify gas mixture module with indicator ippmod(igmix)
| integer(c_int), pointer, save | icondb |
| | Specific condensation modelling if = -1 module not activated if = 0 condensation source terms activated.
| integer(c_int), pointer, save | icondv |
| | Specific condensation modelling if = -1 module not activated if = 0 condensation source terms with metal structures activate.
| integer, save | ienerg = 0 |
| | specific total energy for compressible algorithm
| integer, save | itempk = 0 |
| | temperature deduced from the specific total energy
| real(c_double), pointer, save | viscv0 |
| | reference volume viscosity
| integer, save | ihm = -1 |
| | enthalpy, if transported or if deduced
| real(c_double), pointer, save | srrom |
| | sub-relaxation coefficient for the density
| integer, save | nzfppp |
| | number of boundary zones on current process
General module for specific physics.
