#include "fvm/fvm_defs.h"
| void | fvm_morton_get_coord_extents (int dim, size_t n_coords, const cs_coord_t coords[], cs_coord_t g_extents[]) |
| void | fvm_morton_get_global_extents (int dim, size_t n_extents, const cs_coord_t extents[], cs_coord_t g_extents[]) |
| fvm_morton_code_t | fvm_morton_encode (int dim, fvm_morton_int_t level, const cs_coord_t coords[]) |
| void | fvm_morton_encode_coords (int dim, fvm_morton_int_t level, const cs_coord_t extents[], size_t n_coords, const cs_coord_t coords[], fvm_morton_code_t m_code[]) |
| void | fvm_morton_get_children (int dim, fvm_morton_code_t parent, fvm_morton_code_t children[]) |
| fvm_morton_compare_t | fvm_morton_compare (int dim, fvm_morton_code_t code_a, fvm_morton_code_t code_b) |
| void | fvm_morton_local_order (cs_lnum_t n_codes, const fvm_morton_code_t morton_codes[], cs_lnum_t order[]) |
| void | fvm_morton_local_sort (cs_lnum_t n_codes, fvm_morton_code_t morton_codes[]) |
| bool | fvm_morton_a_gt_b (fvm_morton_code_t a, fvm_morton_code_t b) |
| bool | fvm_morton_a_ge_b (fvm_morton_code_t a, fvm_morton_code_t b) |
| int | fvm_morton_binary_search (cs_lnum_t size, fvm_morton_code_t code, fvm_morton_code_t *codes) |
| void | fvm_morton_s_to_code (double s, void *elt, const void *input) |
| | Function pointer for conversion of a double precision value in range [0, 1] to a given Morton code.
| int | fvm_morton_compare_o (const void *elt1, const void *elt2, const void *input) |
| | Function pointer for comparison of 2 Morton codes.
| void | fvm_morton_dump (int dim, fvm_morton_code_t code) |
◆ fvm_morton_int_t
◆ fvm_morton_compare_t
| Enumerator |
| FVM_MORTON_EQUAL_ID | |
| FVM_MORTON_SAME_ANCHOR | |
| FVM_MORTON_DIFFERENT_ID | |
◆ fvm_morton_a_ge_b()
◆ fvm_morton_a_gt_b()
◆ fvm_morton_binary_search()
◆ fvm_morton_compare()
◆ fvm_morton_compare_o()
| int fvm_morton_compare_o |
const void * | elt1, |
const void * | elt2, |
const void * | input ) |
This function is the same type as that used by qsort_r.
- Parameters
| [in] | elt1 | coordinate between 0 and 1 |
| [in] | elt2 | pointer to optional (untyped) value or structure. |
| [in] | input | pointer to optional (untyped) value or structure. |
- Returns
- < 0 if elt1 < elt2, 0 if elt1 == elt2, > 0 if elt1 > elt2
◆ fvm_morton_dump()
◆ fvm_morton_encode()
◆ fvm_morton_encode_coords()
◆ fvm_morton_get_children()
◆ fvm_morton_get_coord_extents()
| void fvm_morton_get_coord_extents |
int | dim, |
size_t | n_coords, |
const cs_coord_t | coords[], |
cs_coord_t | g_extents[] ) |
◆ fvm_morton_get_global_extents()
| void fvm_morton_get_global_extents |
int | dim, |
size_t | n_extents, |
const cs_coord_t | extents[], |
◆ fvm_morton_local_order()
◆ fvm_morton_local_sort()
◆ fvm_morton_s_to_code()
| void fvm_morton_s_to_code |
double | s, |
void * | elt, |
- Parameters
| [in] | s | coordinate between 0 and 1 |
| [out] | elt | pointer to element |
| [in] | input | pointer to optional (untyped) value or structure; here, this is an interger representing the spatial dimension. |
