| void | fvm_hilbert_get_coord_extents (int dim, size_t n_coords, const cs_coord_t coords[], cs_coord_t g_extents[]) |
| void | fvm_hilbert_encode_coords (int dim, const cs_coord_t extents[], cs_lnum_t n_coords, const cs_coord_t coords[], fvm_hilbert_code_t h_code[]) |
| void | fvm_hilbert_local_order (cs_lnum_t n_codes, const fvm_hilbert_code_t hilbert_codes[], cs_lnum_t order[]) |
| void | fvm_hilbert_local_order_coords (int dim, const cs_coord_t extents[], cs_lnum_t n_coords, const cs_coord_t coords[], cs_lnum_t order[]) |
| void | fvm_hilbert_s_to_code (double s, void *elt, const void *input) |
| | Function pointer for conversion of a double precision value in range [0, 1] to a given Hilbert code.
| int | fvm_hilbert_compare (const void *elt1, const void *elt2, const void *input) |
| | Function pointer for comparison of 2 Hilbert codes.
◆ fvm_hilbert_code_t
◆ fvm_hilbert_compare()
| int fvm_hilbert_compare |
const void * | elt1, |
const void * | elt2, |
const void * | input ) |
This function is the same type as that used by qsort_r.
- Parameters
| [in] | elt1 | coordinate between 0 and 1 |
| [in] | elt2 | pointer to optional (untyped) value or structure. |
| [in] | input | pointer to optional (untyped) value or structure. |
- Returns
- < 0 if elt1 < elt2, 0 if elt1 == elt2, > 0 if elt1 > elt2
◆ fvm_hilbert_encode_coords()
◆ fvm_hilbert_get_coord_extents()
| void fvm_hilbert_get_coord_extents |
int | dim, |
size_t | n_coords, |
const cs_coord_t | coords[], |
cs_coord_t | g_extents[] ) |
◆ fvm_hilbert_local_order()
◆ fvm_hilbert_local_order_coords()
◆ fvm_hilbert_s_to_code()
| void fvm_hilbert_s_to_code |
double | s, |
void * | elt, |
- Parameters
| [in] | s | coordinate between 0 and 1 |
| [out] | elt | pointer to element |
