Local variables to be added
int *nborne;
char name[8];
Computation of intensity (A/m2) for each electrode
Pre initialization
for (int i = 0; i < nbelec; i++) {
sir[i] = 0.;
sii[i] = 0.;
for (int i = 0; i < nbtrf; i++) {
sirt[i] = 0.;
siit[i] = 0.;
nborne[i] = 0;
sprintf(name,
"%07d", transfo->
ielecc[i]);
if (ieljou == 4)
sir[i] += cpro_curre[cell_id][id] * b_face_normal[id][face_id];
if (ieljou == 4)
sii[i] += cpro_curim[cell_id][id] * b_face_normal[id][face_id];
Definition of Voltage on each termin of transformers
Computation of Intensity on each termin of transformers:
if (ieljou == 4)
if (transfo->
ielect[i] != 0) {
if (ieljou == 4)
RVoltage on each termin:
for (int ntf = 0; ntf < nbtrf; ntf++) {
if (transfo->
ibrpr[ntf] == 0 &&
nborne[ntf] = 3;
ur[ntf][0] = 1.154675 * transfo->
tenspr[ntf]
+ (transfo->
zr[ntf] * sirb[ntf][0]
- transfo->
zi[ntf] * siib[ntf][0]) / rnbs2;
ur[ntf][1] = -0.5773 * transfo->
tenspr[ntf]
+ (transfo->
zr[ntf] * sirb[ntf][1]
- transfo->
zi[ntf] * siib[ntf][1]) / rnbs2;
ur[ntf][2] =-0.5773 * transfo->
tenspr[ntf]
+ (transfo->
zr[ntf] * sirb[ntf][2]
- transfo->
zi[ntf] * siib[ntf][2]) / rnbs2;
ui[ntf][0] = (transfo->
zi[ntf] * sirb[ntf][0]
- transfo->
zr[ntf] * siib[ntf][0]) / rnbs2;
ui[ntf][1] = (transfo->
zi[ntf] * sirb[ntf][1]
- transfo->
zr[ntf] * siib[ntf][1]) / rnbs2;
ui[ntf][2] = (transfo->
zi[ntf] * sirb[ntf][2]
- transfo->
zr[ntf] * siib[ntf][2]) / rnbs2;
else
"transformer matrix not defined\n"));
Total intensity for a transformer (zero valued WHEN Offset established):
sirt[ntf] = 0.;
if (ieljou == 4)
siit[ntf] = 0.;
if (transfo->
ielect[i] != 0) {
sirt[i] += sir[i];
if (ieljou == 4)
siit[i] += sii[i];
Take in account of Offset:
transfo->
uroff[ntf] += sirt[ntf] / capaeq;
if (ieljou == 4)
transfo->
uioff[ntf] += siit[ntf] / capaeq;
for (int nb = 0; nb < nborne[ntf]; nb++) {
ur[ntf][nb] += transfo->
uroff[ntf];
if (ieljou == 4)
ui[ntf][nb] += transfo->
uioff[ntf];
" ---------------------------------------\n"
"\n"
" ---------------------------------\n"
" Number of Transformers UROFF\n"
" ---------------------------------\n");
bft_printf(
" ---------------------------------------\n");
Take in account of Boundary Conditions
int *potr_icodcl =
CS_F_(
potr)->bc_coeffs->icodcl;
int *poti_icodcl = nullptr;
if (ieljou == 4) {
poti_icodcl =
CS_F_(
poti_rcodcl1 =
CS_F_(
potr)->bc_coeffs->rcodcl1;
poti_rcodcl3 =
CS_F_(
potr)->bc_coeffs->rcodcl3;
sprintf(name,
"%07d", transfo->
ielecc[i]);
if (transfo->
ielect[i] != 0) {
potr_icodcl[face_id] = 1;
potr_rcodcl1[face_id] = ur[transfo->
ielect[i]][transfo->
ielecb[i]];
if (ieljou == 4) {
poti_icodcl[face_id] = 1;
poti_rcodcl1[face_id] = ur[transfo->
ielecb[i]];
else {
potr_icodcl[face_id] = 3;
potr_rcodcl3[face_id] = 0.;
if (ieljou == 4) {
poti_icodcl[face_id] = 3;
poti_rcodcl3[face_id] = 0.;
int found = 0;
for (
cs_lnum_t face_id = 0; face_id < n_b_faces; face_id++) {
if (potr_icodcl[face_id] == 1) {
if (ieljou == 3) {
if (fabs(potr_rcodcl1[face_id]) < 1.e-20)
found = 1;
else if (ieljou == 4) {
if (fabs(poti_rcodcl1[face_id]) < 1.e-20 && val < 1.e-20)
found = 1;
if (!found)
"Lack of reference: choose a transformer for which\n"
"offset is assumed zero or a face at ground on the\n"
"boundary."));
Finalization step
Test, if not any reference transformer a piece of wall may be at ground:
