Definition and modification of the calculation mesh. More...
#include "base/cs_defs.h"#include <assert.h>#include <math.h>#include <stdarg.h>#include <stdlib.h>#include <stdio.h>#include <string.h>#include "cs_headers.h"Functions | |
| void | cs_user_mesh_restart_mode (void) |
| Force preprocessing behavior in case of restart. | |
| void | cs_user_mesh_input (void) |
| Define mesh files to read and optional associated transformations. | |
| void | cs_user_join (void) |
| Define mesh joinings. | |
| void | cs_user_periodicity (void) |
| Define periodic faces. | |
| void | cs_user_mesh_warping (void) |
| Set options for cutting of warped faces. | |
| void | cs_user_mesh_boundary (cs_mesh_t *mesh) |
| Insert boundaries into a mesh. | |
| void | cs_user_mesh_modify (cs_mesh_t *mesh) |
| Modify geometry and mesh. | |
| void | cs_user_mesh_smoothe (cs_mesh_t *mesh) |
| Mesh smoothing. | |
| void | cs_user_mesh_save (cs_mesh_t *mesh) |
| Enable or disable mesh saving. | |
| void | cs_user_mesh_bad_cells_tag (cs_mesh_t *mesh, cs_mesh_quantities_t *mesh_quantities) |
| Tag bad cells within the mesh based on user-defined geometric criteria. | |
| void | cs_user_mesh_modify_partial (cs_mesh_t *mesh, cs_mesh_quantities_t *mesh_quantities) |
| Apply partial modifications to the mesh after the preprocessing stage, but before initial postprocessing mesh building. | |
| void | cs_user_mesh_cartesian_define (void) |
| Define a cartesian mesh. | |
See Examples of mesh modifications for examples.
| void cs_user_join | ( | void | ) |
| void cs_user_mesh_bad_cells_tag | ( | cs_mesh_t * | mesh, |
| cs_mesh_quantities_t * | mesh_quantities ) |
| [in,out] | mesh | pointer to a cs_mesh_t structure |
| [in,out] | mesh_quantities | pointer to a cs_mesh_quantities_t structure |
| void cs_user_mesh_boundary | ( | cs_mesh_t * | mesh | ) |
| void cs_user_mesh_cartesian_define | ( | void | ) |
| void cs_user_mesh_input | ( | void | ) |
| void cs_user_mesh_modify | ( | cs_mesh_t * | mesh | ) |
| void cs_user_mesh_modify_partial | ( | cs_mesh_t * | mesh, |
Apply partial modifications to the mesh after the preprocessing and initial postprocessing mesh building stage.
| void cs_user_mesh_restart_mode | ( | void | ) |
By default, in case of restart, if a "restart/mesh_input.csm" file is present, it will be read and proprocessing will be skipped.
This behavior may be changed in the GUI (in the "Mesh" section, unchecking "Use unmodified checkpoint mesh in case of restart"), or by calling cs_preprocessor_data_set_restart_mode in this function.
| void cs_user_mesh_save | ( | cs_mesh_t * | mesh | ) |
By default, mesh is saved when modified.
| void cs_user_mesh_smoothe | ( | cs_mesh_t * | mesh | ) |
Mesh smoothing.
| void cs_user_mesh_warping | ( | void | ) |
| void cs_user_periodicity | ( | void | ) |
