User functions for boundary condition definitions. More...
#include "base/cs_defs.h"#include <assert.h>#include <math.h>#include <stdio.h>#include <string.h>#include "cs_headers.h"Functions | |
| void | cs_user_boundary_conditions_setup (cs_domain_t *domain) |
| Set boundary conditions to be applied. | |
| void | cs_user_boundary_conditions (cs_domain_t *domain, int bc_type[]) |
| User definition of boundary conditions. | |
| void | cs_user_boundary_conditions_ale (cs_domain_t *domain, int bc_type[], int ale_bc_type[], int impale[]) |
| User definition of boundary conditions for ALE. | |
| void cs_user_boundary_conditions | ( | cs_domain_t * | domain, |
| int | bc_type[] ) |
| [in,out] | bc_type | boundary face types |
The icodcl and rcodcl arrays are pre-initialized based on default and GUI-defined definitions, and may be modified here.
For a given variable field f, and a given face "face_id", these arrays may be used as follows:
For vector or tensor fields, these arrays are not interleaved, so for a given face "face_id" and field component "comp_id", access is as follows (where n_b_faces is domain->mesh->n_b_faces):
f->bc_coeffs->rcodcl1[n_b_faces*comp_id + face_id]
f->bc_coeffs->rcodcl2[n_b_faces*comp_id + face_id]
f->bc_coeffs->rcodcl3[n_b_faces*comp_id + face_id]
Only the icodcl code values from the first component are used in the case of vector or tensor fields, so the icodcl values can be defined as for a scalar.
| void cs_user_boundary_conditions_ale | ( | cs_domain_t * | domain, |
| int | bc_type[], | ||
| int | ale_bc_type[], | ||
| int | impale[] ) |
See Boundary conditions for ALE (Arbitrary Lagrangian Eulerian) for additional details.
| [in,out] | ale_bc_type | boundary face types for mesh velocity (see cs_boundary_ale_subtype_bits_t) |
| [in] | impale | indicator for prescribed node displacement (0 or 1) |
| void cs_user_boundary_conditions_setup | ( | cs_domain_t * | domain | ) |
This function is called just before cs_user_finalize_setup, and boundary conditions can be defined in either of those functions, depending on whichever is considered more readable or practical for a given use.
