cs_sles_pc_cuda.h
1#ifndef __CS_SLES_PC_CUDA_H__
2#define __CS_SLES_PC_CUDA_H__
5 * Sparse Linear Equation Solver Preconditioners using CUDA
31 * Local headers
34#include "base/cs_base.h"
35#include "alge/cs_matrix.h"
36#include "alge/cs_sles.h"
37#include "alge/cs_sles_pc.h"
38
43/*============================================================================
44 * Macro definitions
46
48 * Type definitions
50
51/*============================================================================
52 * Global variables
53 *============================================================================*/
54
55/*=============================================================================
56 * User function prototypes
58
59/*=============================================================================
60 * Public function prototypes
61 *============================================================================*/
62
63/*----------------------------------------------------------------------------
64 * Function for application of a null-preconditioner.
65 *
66 * In cases where it is desired that the preconditioner modify a vector
67 * "in place", x_in should be set to NULL, and x_out contain the vector to
68 * be modified (\f$x_{out} \leftarrow M^{-1}x_{out})\f$).
69 *
70 * parameters:
71 * context <-> pointer to preconditioner context
72 * x_in <-- input vector
73 * x_out <-> input/output vector
74 *
75 * returns:
76 * preconditioner application status
77 *----------------------------------------------------------------------------*/
78
81 const cs_real_t *x_in,
82 cs_real_t *x_out);
83
84/*----------------------------------------------------------------------------
85 * Function for application of a Jacobi preconditioner.
86 *
87 * In cases where it is desired that the preconditioner modify a vector
88 * "in place", x_in should be set to NULL, and x_out contain the vector to
89 * be modified (\f$x_{out} \leftarrow M^{-1}x_{out})\f$).
90 *
91 * parameters:
92 * context <-> pointer to preconditioner context
93 * x_in <-- input vector
94 * x_out <-> input/output vector
95 *
96 * returns:
97 * preconditioner application status
98 *----------------------------------------------------------------------------*/
99
102 const cs_real_t *x_in,
103 cs_real_t *x_out);
104
105/*----------------------------------------------------------------------------
106 * Function for application of a polynomial preconditioner.
107 *
108 * In cases where it is desired that the preconditioner modify a vector
109 * "in place", x_in should be set to NULL, and x_out contain the vector to
110 * be modified (\f$x_{out} \leftarrow M^{-1}x_{out})\f$).
111 *
112 * parameters:
113 * context <-> pointer to preconditioner context
114 * x_in <-- input vector
115 * x_out <-> input/output vector
116 *
117 * returns:
118 * preconditioner application status
119 *----------------------------------------------------------------------------*/
120
123 const cs_real_t *x_in,
124 cs_real_t *x_out);
125
126/*----------------------------------------------------------------------------*/
127
129
130#endif /* __CS_SLES_PC_CUDA_H__ */
Definition cs_defs.h:542
Definition cs_defs.h:342
Definition cs_defs.h:543
cs_sles_pc_state_t
Definition cs_sles_pc.h:55
cs_sles_pc_state_t cs_sles_pc_cuda_apply_jacobi(void *context, const cs_real_t *x_in, cs_real_t *x_out)
cs_sles_pc_state_t cs_sles_pc_cuda_apply_none(void *context, const cs_real_t *x_in, cs_real_t *x_out)
cs_sles_pc_state_t cs_sles_pc_cuda_apply_poly(void *context, const cs_real_t *x_in, cs_real_t *x_out)
