#include "base/cs_base.h"#include "base/cs_halo_perio.h"#include "alge/cs_matrix.h"#include "alge/cs_param_sles.h"#include "base/cs_time_plot.h"#include "alge/cs_sles.h"#include "alge/cs_sles_pc.h"Go to the source code of this file.
Macros | |
| #define | ICNTL(I) |
| #define | CNTL(I) |
| #define | INFOG(I) |
| #define | INFO(I) |
| #define | RINFOG(I) |
| #define | RINFO(I) |
| #define | KEEP(I) |
| typedef void | cs_sles_mumps_setup_hook_t(const cs_param_sles_t *slesp, void *context, void *mumps) |
| Function pointer for user settings of a MUMPS solver. This function is called at the end of the setup stage. | |
| typedef struct _cs_sles_mumps_t | cs_sles_mumps_t |
| void | cs_user_sles_mumps_hook (const cs_param_sles_t *slesp, void *context, void *pmumps) |
| Function pointer for advanced user settings of a MUMPS solver. This function is called two times during the setup stage. | |
| void | cs_sles_mumps_set_zero_dthreshold (double thr) |
| Modifiy the default value used as a threshold to clean matrix values sent to MUMPS in case of factorization with "double precisiion". | |
| void | cs_sles_mumps_set_zero_sthreshold (double thr) |
| Modifiy the default value used as a threshold to clean matrix values sent to MUMPS in case of factorization in "single precisiion". | |
| cs_sles_mumps_t * | cs_sles_mumps_define (int f_id, const char *name, const cs_param_sles_t *slesp, cs_sles_mumps_setup_hook_t *setup_hook, void *context) |
| Define and associate a MUMPS linear system solver for a given field or equation name. | |
| cs_sles_pc_t * | cs_sles_mumps_pc_create (const cs_param_sles_t *slesp) |
| Create a preconditioner structure relying on MUMPS solver. | |
| cs_sles_mumps_t * | cs_sles_mumps_create (const cs_param_sles_t *slesp, cs_sles_mumps_setup_hook_t *setup_hook, void *context) |
| Create MUMPS linear system solver info and context. | |
| void * | cs_sles_mumps_copy (const void *context) |
| Create MUMPS linear system solver info and context based on existing info and context. | |
| void | cs_sles_mumps_free (void *context) |
| Free MUMPS linear equation solver setup context. | |
| void | cs_sles_mumps_destroy (void **context) |
| Destroy MUMPS linear system solver info and context. | |
| void | cs_sles_mumps_setup (void *context, const char *name, const cs_matrix_t *a, int verbosity) |
| Setup MUMPS linear equation solver. | |
| cs_sles_convergence_state_t | cs_sles_mumps_solve (void *context, const char *name, const cs_matrix_t *a, int verbosity, double precision, double r_norm, int *n_iter, double *residual, const cs_real_t *rhs, cs_real_t *vx_ini, cs_real_t *vx, size_t aux_size, void *aux_vectors) |
| Call MUMPS linear equation solver. | |
| void | cs_sles_mumps_log (const void *context, cs_log_t log_type) |
| Log sparse linear equation solver info. | |
| void | cs_sles_mumps_library_info (cs_log_t log_type) |
| Print information on MUMPS library. | |
| #define CNTL | ( | I | ) |
| #define ICNTL | ( | I | ) |
| #define INFO | ( | I | ) |
| #define INFOG | ( | I | ) |
| #define KEEP | ( | I | ) |
| #define RINFO | ( | I | ) |
| #define RINFOG | ( | I | ) |
| typedef void cs_sles_mumps_setup_hook_t(const cs_param_sles_t *slesp, void *context, void *mumps) |
Function pointer for user settings of a MUMPS DMUMPS_STRUC_C solver setup.
Note: if the context pointer is non-null, it must point to valid data when the selection function is called so that value or structure should not be temporary (i.e. local);
| [in] | slesp | pointer to the related cs_param_sles_t structure |
| [in,out] | context | pointer to optional (untyped) value or structure |
| [in,out] | mumps | pointer to DMUMPS_STRUC_C or SMUMPS_STRUC_C |
This function is called the end of the setup stage.
| [in,out] | dmumps | pointer to DMUMPS_STRUC_C structure |
| typedef struct _cs_sles_mumps_t cs_sles_mumps_t |
| void * cs_sles_mumps_copy | ( | const void * | context | ) |
| [in] | context | pointer to reference info and context (actual type: cs_sles_mumps_t *) |
| cs_sles_mumps_t * cs_sles_mumps_create | ( | const cs_param_sles_t * | slesp, |
| cs_sles_mumps_setup_hook_t * | setup_hook, | ||
| void * | context ) |
| [in] | slesp | pointer to a cs_param_sles_t structure |
| [in] | setup_hook | pointer to optional setup epilogue function |
| [in,out] | context | pointer to optional (untyped) value or structure for setup_hook, or NULL |
| [in,out] | context | pointer to optional (untyped) value or structure for setup_hook, or nullptr |
| cs_sles_mumps_t * cs_sles_mumps_define | ( | int | f_id, |
| const char * | name, | ||
| const cs_param_sles_t * | slesp, | ||
This is a utility function: if finer control is needed, see cs_sles_define and cs_sles_mumps_create.
Note that this function returns a pointer directly to the sparse direct solver management structure. This may be used to set further options. If needed, cs_sles_find may be used to obtain a pointer to the matching cs_sles_t container.
| [in] | name | associated name if f_id < 0, or nullptr |
| void cs_sles_mumps_destroy | ( | void ** | context | ) |
| [in,out] | context | pointer to sparse direct solver info and context (actual type: cs_sles_mumps_t **) |
| void cs_sles_mumps_free | ( | void * | context | ) |
| [in,out] | context | pointer to sparse direct solver info and context (actual type: cs_sles_mumps_t *) |
| void cs_sles_mumps_library_info | ( | cs_log_t | log_type | ) |
| void cs_sles_mumps_log | ( | const void * | context, |
| cs_log_t | log_type ) |
| [in] | context | pointer to sparse direct solver info and context (actual type: cs_sles_mumps_t *) |
| cs_sles_pc_t * cs_sles_mumps_pc_create | ( | const cs_param_sles_t * | slesp | ) |
| void cs_sles_mumps_set_zero_dthreshold | ( | double | thr | ) |
If thr < 0, there is no cleaning
| [in] | thr | value of the threshold to set |
| void cs_sles_mumps_set_zero_sthreshold | ( | double | thr | ) |
| void cs_sles_mumps_setup | ( | void * | context, |
| int | verbosity ) |
| cs_sles_convergence_state_t cs_sles_mumps_solve | ( | void * | context, |
| int | verbosity, | ||
| double | precision, | ||
| double | r_norm, | ||
| int * | n_iter, | ||
| double * | residual, | ||
| cs_real_t * | vx_ini, | ||
| cs_real_t * | vx, | ||
| size_t | aux_size, | ||
| void * | aux_vectors ) |
| [in] | a | matrix |
| [in] | a | matrix |
| aux_vectors | optional working area (internal allocation if nullptr) |
| void cs_user_sles_mumps_hook | ( | const cs_param_sles_t * | slesp, |
| void * | context, | ||
| void * | pmumps ) |
One can recover the MUMPS step through the "job" member. MUMPS_JOB_ANALYSIS or MUMPS_JOB_FACTORIZATION
Note: if the context pointer is non-null, it must point to valid data when the selection function is called so that structure should not be temporary (i.e. local);
| [in,out] | pmumps | pointer to DMUMPS_STRUC_C or SMUMPS_STRUC_C struct. |
