cs_sles_it_cuda.h
1#ifndef __CS_SLES_IT_CUDA_H__
2#define __CS_SLES_IT_CUDA_H__
5 * Sparse Linear Equation Solvers using CUDA
31 * Local headers
34#include "base/cs_base.h"
35#include "alge/cs_matrix.h"
36#include "alge/cs_sles.h"
37#include "alge/cs_sles_pc.h"
38
43/*============================================================================
44 * Macro definitions
46
48 * Type definitions
50
51/*============================================================================
52 * Global variables
53 *============================================================================*/
54
55/*=============================================================================
56 * User function prototypes
58
59/*=============================================================================
60 * Public function prototypes
61 *============================================================================*/
62
63/*----------------------------------------------------------------------------
64 * Solution of A.vx = Rhs using Jacobi.
65 *
66 * On entry, vx is considered initialized.
67 *
68 * parameters:
69 * c <-- pointer to solver context info
70 * a <-- linear equation matrix
71 * diag_block_size <-- diagonal block size
72 * rotation_mode <-- halo update option for rotational periodicity
73 * convergence <-- convergence information structure
74 * rhs <-- right hand side
75 * vx_ini <-- initial system solution
76 * (vx if nonzero, nullptr if zero)
77 * vx <-> system solution
78 * aux_size <-- number of elements in aux_vectors (in bytes)
79 * aux_vectors --- optional working area (allocation otherwise)
80 *
81 * returns:
82 * convergence state
83 *----------------------------------------------------------------------------*/
84
87 const cs_matrix_t *a,
88 cs_lnum_t diag_block_size,
89 cs_sles_it_convergence_t *convergence,
90 const cs_real_t *rhs,
91 cs_real_t *vx_ini,
92 cs_real_t *vx,
93 size_t aux_size,
94 void *aux_vectors);
95
96/*----------------------------------------------------------------------------
97 * Solution of A.vx = Rhs using block Jacobi.
98 *
99 * On entry, vx is considered initialized.
100 *
101 * parameters:
102 * c <-- pointer to solver context info
103 * a <-- linear equation matrix
104 * diag_block_size <-- diagonal block size
105 * rotation_mode <-- halo update option for rotational periodicity
106 * convergence <-- convergence information structure
107 * rhs <-- right hand side
108 * vx_ini <-- initial system solution
109 * (vx if nonzero, nullptr if zero)
110 * vx <-> system solution
111 * aux_size <-- number of elements in aux_vectors (in bytes)
112 * aux_vectors --- optional working area (allocation otherwise)
113 *
114 * returns:
115 * convergence state
116 *----------------------------------------------------------------------------*/
117
120 const cs_matrix_t *a,
121 cs_lnum_t diag_block_size,
122 cs_sles_it_convergence_t *convergence,
123 const cs_real_t *rhs,
124 cs_real_t *vx_ini,
125 cs_real_t *vx,
126 size_t aux_size,
127 void *aux_vectors);
128
129/*----------------------------------------------------------------------------
130 * Solution of A.vx = Rhs using flexible preconditioned conjugate gradient.
131 *
132 * Compared to standard PCG, FCG supports variable preconditioners.
133 *
134 * This variant, described in \cite Notay:2015, allows computing the
135 * required inner products with a single global communication.
136 *
137 * On entry, vx is considered initialized.
138 *
139 * parameters:
140 * c <-- pointer to solver context info
141 * a <-- matrix
142 * diag_block_size <-- diagonal block size
143 * convergence <-- convergence information structure
144 * rhs <-- right hand side
145 * vx_ini <-- initial system solution
146 * (vx if nonzero, nullptr if zero)
147 * vx <-> system solution
148 * aux_size <-- number of elements in aux_vectors (in bytes)
149 * aux_vectors --- optional working area (allocation otherwise)
150 *
151 * returns:
152 * convergence state
153 *----------------------------------------------------------------------------*/
154
157 const cs_matrix_t *a,
158 cs_lnum_t diag_block_size,
159 cs_sles_it_convergence_t *convergence,
160 const cs_real_t *rhs,
161 cs_real_t *vx_ini,
162 cs_real_t *vx,
163 size_t aux_size,
164 void *aux_vectors);
165
166/*----------------------------------------------------------------------------
167 * Solution of A.vx = Rhs using optimised preconditioned GCR (CUDA version).
168 *
169 * On entry, vx is considered initialized.
170 *
171 * parameters:
172 * c <-- pointer to solver context info
173 * a <-- matrix
174 * diag_block_size <-- diagonal block size (unused here)
175 * convergence <-- convergence information structure
176 * rhs <-- right hand side
177 * vx_ini <-- initial system solution
178 * (vx if nonzero, nullptr if zero)
179 * vx <-> system solution
180 * aux_size <-- number of elements in aux_vectors (in bytes)
181 * aux_vectors --- optional working area (allocation otherwise)
182 *
183 * returns:
184 * convergence state
185 *----------------------------------------------------------------------------*/
186
189 const cs_matrix_t *a,
190 cs_lnum_t diag_block_size,
191 cs_sles_it_convergence_t *convergence,
192 const cs_real_t *rhs,
193 cs_real_t *vx_ini,
194 cs_real_t *vx,
195 size_t aux_size,
196 void *aux_vectors);
197
198/*----------------------------------------------------------------------------*/
199
201
202#endif /* __CS_SLES_IT_CUDA_H__ */
Definition cs_defs.h:542
Definition cs_defs.h:342
Definition cs_defs.h:543
Definition cs_defs.h:335
Definition cs_matrix.h:110
cs_sles_convergence_state_t
Definition cs_sles.h:56
struct _cs_sles_it_t cs_sles_it_t
Definition cs_sles_it.h:86
struct _cs_sles_it_convergence_t cs_sles_it_convergence_t
Definition cs_sles_it.h:90
cs_sles_convergence_state_t cs_sles_it_cuda_jacobi(cs_sles_it_t *c, const cs_matrix_t *a, cs_lnum_t diag_block_size, cs_sles_it_convergence_t *convergence, const cs_real_t *rhs, cs_real_t *vx_ini, cs_real_t *vx, size_t aux_size, void *aux_vectors)
cs_sles_convergence_state_t cs_sles_it_cuda_fcg(cs_sles_it_t *c, const cs_matrix_t *a, cs_lnum_t diag_block_size, cs_sles_it_convergence_t *convergence, const cs_real_t *rhs, cs_real_t *vx_ini, cs_real_t *vx, size_t aux_size, void *aux_vectors)
cs_sles_convergence_state_t cs_sles_it_cuda_gcr(cs_sles_it_t *c, const cs_matrix_t *a, cs_lnum_t diag_block_size, cs_sles_it_convergence_t *convergence, const cs_real_t *rhs, cs_real_t *vx_ini, cs_real_t *vx, size_t aux_size, void *aux_vectors)
cs_sles_convergence_state_t cs_sles_it_cuda_block_jacobi(cs_sles_it_t *c, const cs_matrix_t *a, cs_lnum_t diag_block_size, cs_sles_it_convergence_t *convergence, const cs_real_t *rhs, cs_real_t *vx_ini, cs_real_t *vx, size_t aux_size, void *aux_vectors)
