cs_sles_hypre.h File Reference
#include "base/cs_base.h"
#include "alge/cs_matrix.h"
#include "alge/cs_sles.h"
Include dependency graph for cs_sles_hypre.h:
Typedefs
typedef void cs_sles_hypre_setup_hook_t(int verbosity, void *context, void *solver)
 Function pointer for settings of a HYPRE solver setup.
typedef struct _cs_sles_hypre_t cs_sles_hypre_t
Enumerations
enum  cs_sles_hypre_type_t {
  CS_SLES_HYPRE_BOOMERAMG , CS_SLES_HYPRE_HYBRID , CS_SLES_HYPRE_ILU , CS_SLES_HYPRE_BICGSTAB ,
  CS_SLES_HYPRE_GMRES , CS_SLES_HYPRE_FLEXGMRES , CS_SLES_HYPRE_LGMRES , CS_SLES_HYPRE_PCG ,
  CS_SLES_HYPRE_EUCLID , CS_SLES_HYPRE_PARASAILS , CS_SLES_HYPRE_NONE
cs_sles_hypre_tcs_sles_hypre_define (int f_id, const char *name, cs_sles_hypre_type_t solver_type, cs_sles_hypre_type_t precond_type, cs_sles_hypre_setup_hook_t *setup_hook, void *context)
 Define and associate a HYPRE linear system solver for a given field or equation name.
cs_sles_hypre_tcs_sles_hypre_create (cs_sles_hypre_type_t solver_type, cs_sles_hypre_type_t precond_type, cs_sles_hypre_setup_hook_t *setup_hook, void *context)
 Create HYPRE linear system solver info and context.
void cs_sles_hypre_destroy (void **context)
 Destroy iterative sparse linear system solver info and context.
void * cs_sles_hypre_copy (const void *context)
 Create HYPRE sparse linear system solver info and context based on existing info and context.
void cs_sles_hypre_setup (void *context, const char *name, const cs_matrix_t *a, int verbosity)
 Setup iterative sparse linear equation solver.
cs_sles_convergence_state_t cs_sles_hypre_solve (void *context, const char *name, const cs_matrix_t *a, int verbosity, double precision, double r_norm, int *n_iter, double *residual, const cs_real_t *rhs, cs_real_t *vx_ini, cs_real_t *vx, size_t aux_size, void *aux_vectors)
 Call HYPRE linear equation solver.
void cs_sles_hypre_free (void *context)
 Free HYPRE linear equation solver setup context.
bool cs_sles_hypre_error_post_and_abort (cs_sles_t *sles, cs_sles_convergence_state_t state, const cs_matrix_t *a, const cs_real_t *rhs, cs_real_t *vx)
 Error handler for HYPRE solver.
void cs_sles_hypre_log (const void *context, cs_log_t log_type)
 Log sparse linear equation solver info.
void cs_sles_hypre_set_n_max_iter (cs_sles_hypre_t *context, int n_max_iter)
 Set the max. number of iterations associated to the given HYPRE contrext.
void cs_sles_hypre_set_host_device (cs_sles_hypre_t *context, int use_device)
 Define whether the solver should run on the host or accelerated device.
int cs_sles_hypre_get_host_device (const cs_sles_hypre_t *context)
 Query whether the solver should run on the host or accelerated device.
void cs_sles_hypre_library_info (cs_log_t log_type)
 Print information on hypre library.
Typedef Documentation
◆ cs_sles_hypre_setup_hook_t
This function is called during the setup stage for a HYPRE solver.
When first called, the solver argument is nullptr, and must be created using HYPRE functions.
Note: if the context pointer is non-null, it must point to valid data when the selection function is called so that value or structure should not be temporary (i.e. local);
[in]verbosityverbosity level
[in,out]contextpointer to optional (untyped) value or structure
[in,out]solverhandle to HYPRE solver (to be cast as HYPRE_Solver)
◆ cs_sles_hypre_t
◆ cs_sles_hypre_type_t
Enumerator
BoomerAMG (algebraic multigrid)
Hybrid solver
CS_SLES_HYPRE_ILU
hypre-ILU (incomplete LU)
BiCGSTAB
CS_SLES_HYPRE_GMRES
GMRES
Flexible GMRES
LGMRES
CS_SLES_HYPRE_PCG
Preconditioned Congugate Gradient
ParaSails (sparse approximate inverse))
CS_SLES_HYPRE_NONE
No solver or preconditioner
◆ cs_sles_hypre_copy()
void * cs_sles_hypre_copy ( const void * context)
[in]contextpointer to reference info and context (actual type: cs_sles_hypre_t *)
pointer to newly created solver info object. (actual type: cs_sles_hypre_t *)
◆ cs_sles_hypre_create()
cs_sles_hypre_t * cs_sles_hypre_create ( cs_sles_hypre_type_t solver_type,
cs_sles_hypre_setup_hook_t * setup_hook,
void * context )
[in]solver_typeHYPRE solver type
[in]precond_typeHYPRE preconditioner type
[in]setup_hookpointer to optional setup epilogue function
[in]contextpointer to optional (untyped) value or structure for setup_hook, or NULL
pointer to newly created linear system object.
[in]contextpointer to optional (untyped) value or structure for setup_hook, or nullptr
◆ cs_sles_hypre_define()
cs_sles_hypre_t * cs_sles_hypre_define ( int f_id,
const char * name,
void * context )
This is a utility function: if finer control is needed, see cs_sles_define and cs_sles_petsc_create.
The associated solver required that the matrix passed to it is a HYPRE matrix (see cs_matrix_set_type_hypre).
Note that this function returns a pointer directly to the iterative solver management structure. This may be used to set further options. If needed, cs_sles_find may be used to obtain a pointer to the matching cs_sles_t container.
[in]nameassociated name if f_id < 0, or NULL
[in,out]contextpointer to optional (untyped) value or structure for setup_hook, or NULL
pointer to newly created iterative solver info object.
[in]nameassociated name if f_id < 0, or nullptr
[in,out]contextpointer to optional (untyped) value or structure for setup_hook, or nullptr
◆ cs_sles_hypre_destroy()
void cs_sles_hypre_destroy ( void ** context)
[in,out]contextpointer to iterative solver info and context (actual type: cs_sles_hypre_t **)
◆ cs_sles_hypre_error_post_and_abort()
bool cs_sles_hypre_error_post_and_abort ( cs_sles_t * sles,
const cs_matrix_t * a,
const cs_real_t * rhs,
cs_real_t * vx )
In case of divergence or breakdown, this error handler outputs an error message It does nothing in case the maximum iteration count is reached.
[in,out]slespointer to solver object
[in]stateconvergence state
[in]amatrix
[in]rhsright hand side
[in,out]vxsystem solution
false (do not attempt new solve)
◆ cs_sles_hypre_free()
void cs_sles_hypre_free ( void * context)
[in,out]contextpointer to iterative solver info and context (actual type: cs_sles_hypre_t *)
◆ cs_sles_hypre_get_host_device()
int cs_sles_hypre_get_host_device ( const cs_sles_hypre_t * context)
[in,out]contextpointer to HYPRE linear solver info
0 for host, 1 for device (GPU)
◆ cs_sles_hypre_library_info()
void cs_sles_hypre_library_info ( cs_log_t log_type)
[in]log_typelog type
◆ cs_sles_hypre_log()
void cs_sles_hypre_log ( const void * context,
cs_log_t log_type )
[in]contextpointer to iterative solver info and context (actual type: cs_sles_hypre_t *)
◆ cs_sles_hypre_set_host_device()
void cs_sles_hypre_set_host_device ( cs_sles_hypre_t * context,
int use_device )
If no device is available, this setting is ignored.
[in]use_device0 for host, 1 for device (GPU)
◆ cs_sles_hypre_set_n_max_iter()
void cs_sles_hypre_set_n_max_iter ( cs_sles_hypre_t * context,
int n_max_iter )
[in]n_max_itermax. number of iterations
◆ cs_sles_hypre_setup()
void cs_sles_hypre_setup ( void * context,
const char * name,
int verbosity )
[in]namepointer to system name
[in]aassociated matrix
[in]verbosityassociated verbosity
◆ cs_sles_hypre_solve()
cs_sles_convergence_state_t cs_sles_hypre_solve ( void * context,
const char * name,
int verbosity,
double precision,
double r_norm,
int * n_iter,
double * residual,
cs_real_t * vx_ini,
cs_real_t * vx,
size_t aux_size,
void * aux_vectors )
[in]amatrix
[in]precisionsolver precision
[in]r_normresidual normalization
[out]residualresidual
[in]vx_iniinitial system solution (vx if nonzero, nullptr if zero)
[in]aux_sizenumber of elements in aux_vectors (in bytes)
aux_vectorsoptional working area (internal allocation if nullptr)
convergence state
