cs_sles_amgx.h File Reference
#include "base/cs_base.h"
#include "alge/cs_matrix.h"
#include "alge/cs_sles.h"
Include dependency graph for cs_sles_amgx.h:
Macros
#define CS_SLES_AMGX_PREFER_COMM_FROM_MAPS   (1 << 0)
Typedefs
typedef struct _cs_sles_amgx_t cs_sles_amgx_t
cs_sles_amgx_tcs_sles_amgx_define (int f_id, const char *name)
 Define and associate an AmgX linear system solver for a given field or equation name.
cs_sles_amgx_tcs_sles_amgx_create (void)
 Create AmgX linear system solver info and context.
void * cs_sles_amgx_copy (const void *context)
 Create AmgX linear system solver info and context based on existing info and context.
void cs_sles_amgx_destroy (void **context)
 Destroy AmgX linear system solver info and context.
const char * cs_sles_amgx_get_config (void *context)
 return the solver configuration for an AmgX solver.
void cs_sles_amgx_set_config (void *context, const char *config)
 Define the configuration for an AmgX solver.
const char * cs_sles_amgx_get_config_file (void *context)
 return the name of the solver configuration file for an AmgX solver.
void cs_sles_amgx_set_config_file (void *context, const char *path)
 Set the solver configuration file for an AmgX solver.
bool cs_sles_amgx_get_use_device (void *context)
 Define whether an AmgX solver should use the device or host.
void cs_sles_amgx_set_use_device (void *context, bool use_device)
void cs_sles_amgx_set_flags (void *context, int flags)
 Define additional AmgX solver usage flags.
int cs_sles_amgx_get_flags (void *context)
 Query additional AmgX solver usage flags.
void cs_sles_amgx_setup (void *context, const char *name, const cs_matrix_t *a, int verbosity)
 Setup AmgX linear equation solver.
cs_sles_convergence_state_t cs_sles_amgx_solve (void *context, const char *name, const cs_matrix_t *a, int verbosity, double precision, double r_norm, int *n_iter, double *residual, const cs_real_t *rhs, cs_real_t *vx_ini, cs_real_t *vx, size_t aux_size, void *aux_vectors)
 Call AmgX linear equation solver.
void cs_sles_amgx_free (void *context)
 Free AmgX linear equation solver setup context.
void cs_sles_amgx_log (const void *context, cs_log_t log_type)
 Log sparse linear equation solver info.
void cs_sles_amgx_library_info (cs_log_t log_type)
 Print information on AmgX library.
◆ CS_SLES_AMGX_PREFER_COMM_FROM_MAPS
AmgX wrapper option flags
Use AMGX_comm_from_maps_1_ring instead of AMGX_distribution for parallel matrices when its use seems possible
Typedef Documentation
◆ cs_sles_amgx_t
◆ cs_sles_amgx_copy()
void * cs_sles_amgx_copy ( const void * context)
[in]contextpointer to reference info and context (actual type: cs_sles_amgx_t *)
pointer to newly created solver info object. (actual type: cs_sles_amgx_t *)
◆ cs_sles_amgx_create()
cs_sles_amgx_t * cs_sles_amgx_create ( void )
pointer to associated linear system object.
◆ cs_sles_amgx_define()
cs_sles_amgx_t * cs_sles_amgx_define ( int f_id,
const char * name )
This is a utility function: if finer control is needed, see cs_sles_define and cs_sles_amgx_create.
[in]nameassociated name if f_id < 0, or nullptr
pointer to newly created AmgX solver info object.
◆ cs_sles_amgx_destroy()
void cs_sles_amgx_destroy ( void ** context)
[in,out]contextpointer to AmgX solver info and context (actual type: cs_sles_amgx_t **)
◆ cs_sles_amgx_free()
void cs_sles_amgx_free ( void * context)
[in,out]contextpointer to AmgX solver info and context (actual type: cs_sles_amgx_t *)
◆ cs_sles_amgx_get_config()
const char * cs_sles_amgx_get_config ( void * context)
Check the AmgX docummentation for configuration strings syntax.
◆ cs_sles_amgx_get_config_file()
const char * cs_sles_amgx_get_config_file ( void * context)
Check the AmgX docummentation for configuration file syntax.
configuration file name, or NULL
configuration file name, or nullptr
◆ cs_sles_amgx_get_flags()
int cs_sles_amgx_get_flags ( void * context)
[in]contextpointer to AmgX solver info and context
associated flags
◆ cs_sles_amgx_get_use_device()
bool cs_sles_amgx_get_use_device ( void * context)
By default, the device will be used, but by callingg this function with "use_device = false", only the host will be used.
true for device, false for host only
◆ cs_sles_amgx_library_info()
void cs_sles_amgx_library_info ( cs_log_t log_type)
[in]log_typelog type
◆ cs_sles_amgx_log()
void cs_sles_amgx_log ( const void * context,
cs_log_t log_type )
[in]contextpointer to AmgX solver info and context (actual type: cs_sles_amgx_t *)
◆ cs_sles_amgx_set_config()
void cs_sles_amgx_set_config ( void * context,
const char * config )
If this function is not called, a default configuration will be used.
[in]configstring defining configuration to use
◆ cs_sles_amgx_set_config_file()
void cs_sles_amgx_set_config_file ( void * context,
const char * path )
[in]pathpath to configuration file
◆ cs_sles_amgx_set_flags()
void cs_sles_amgx_set_flags ( void * context,
int flags )
[in]flagsflags (sum/bitwise of) for AmgX usage options.
◆ cs_sles_amgx_set_use_device()
void cs_sles_amgx_set_use_device ( void * context,
bool use_device )
[in]use_devicetrue for devince, false for host only
◆ cs_sles_amgx_setup()
void cs_sles_amgx_setup ( void * context,
const char * name,
const cs_matrix_t * a,
int verbosity )
[in]namepointer to system name
[in]aassociated matrix
[in]verbosityassociated verbosity
◆ cs_sles_amgx_solve()
cs_sles_convergence_state_t cs_sles_amgx_solve ( void * context,
const char * name,
int verbosity,
double precision,
double r_norm,
int * n_iter,
double * residual,
const cs_real_t * rhs,
cs_real_t * vx_ini,
cs_real_t * vx,
size_t aux_size,
void * aux_vectors )
Warning
The precision, r_norm, and n_iter parameters are ignored here. the matching configuration options should be set earlier, using the cs_sles_amgx_set_config function
[in]amatrix
[in]precisionsolver precision
[in]r_normresidual normalization
[out]residualresidual
[in]rhsright hand side
[in]vx_iniinitial system solution (vx if nonzero, nullptr if zero)
[in,out]vxsystem solution
[in]aux_sizenumber of elements in aux_vectors (in bytes)
aux_vectorsoptional working area (internal allocation if nullptr)
convergence state
