#include "base/cs_defs.h"Go to the source code of this file.
| void | cs_rad_transfer_absorption (const cs_real_t tempk[], cs_real_t cpro_cak0[], cs_real_t kgas[], cs_real_t agas[], cs_real_t agasb[]) |
| Compute absorption coefficient for gas mix and particles for pulverized coal or other specific physical models. | |
| void | cs_rad_transfer_rcfsk_absorption (const cs_real_t tempk[], cs_real_t cpro_cak0[], cs_real_t kgas[], cs_real_t agas[], cs_real_t agasb[]) |
| Compute absorption coefficient for the case of gas combustion. | |
| void | cs_rad_transfer_absorption_check_p1 (const cs_real_t cpro_cak[]) |
| Check the absorption validity fo the P-1 approximation. | |
| void cs_rad_transfer_absorption | ( | const cs_real_t | tempk[], |
| cs_real_t | cpro_cak0[], | ||
| cs_real_t | kgas[], | ||
| cs_real_t | agas[], | ||
| cs_real_t | agasb[] ) |
For the P-1 model, this function also checks whether the medium's optical length is at least of the order of unity.
| [in] | tempk | gas phase temperature at cells (in Kelvin) |
| [out] | cpro_cak0 | mdium (gas) Absorption coefficient |
| [out] | kgas | radiation coefficients of the gray gases at cells (per gas) |
| [out] | agas | weights of the gray gases at cells (per gas) |
| [out] | agasb | weights of the gray gases at boundary faces (per gas) |
| [out] | cpro_cak0 | medium (gas) Absorption coefficient |
| void cs_rad_transfer_absorption_check_p1 | ( | const cs_real_t | cpro_cak[] | ) |
For the P-1 model, the medium's optical length should be at least of the order of unity.
| [in] | cpro_cak | absorption coefficient values (at cells) |
| void cs_rad_transfer_rcfsk_absorption | ( | const cs_real_t | tempk[], |
