cs_rad_transfer.h File Reference
#include "base/cs_time_control.h"
Include dependency graph for cs_rad_transfer.h:
Data Structures
struct  cs_rad_transfer_params_t
 Structure containing the radiation module parameters. More...
Enumerations
enum  cs_rad_transfer_model_t { CS_RAD_TRANSFER_NONE = 0 , CS_RAD_TRANSFER_DOM = 1 , CS_RAD_TRANSFER_P1 = 2 }
enum  cs_rad_quadrature_type_t {
  CS_RAD_QUADRATURE_S4 = 1 , CS_RAD_QUADRATURE_S6 , CS_RAD_QUADRATURE_S8 , CS_RAD_QUADRATURE_T2 ,
  CS_RAD_QUADRATURE_T4 , CS_RAD_QUADRATURE_TN , CS_RAD_QUADRATURE_LC11 , CS_RAD_QUADRATURE_DCT020_2468
enum  {
  CS_BOUNDARY_RAD_WALL_GRAY = 1 , CS_BOUNDARY_RAD_WALL_GRAY_1D_T = 4 , CS_BOUNDARY_RAD_WALL_GRAY_EXTERIOR_T = 21 , CS_BOUNDARY_RAD_WALL_REFL_EXTERIOR_T = 22 ,
  CS_BOUNDARY_RAD_WALL_GRAY_COND_FLUX = 31 , CS_BOUNDARY_RAD_WALL_REFL_COND_FLUX = 32
enum  {
  CS_RAD_ATMO_3D_NONE = 0 , CS_RAD_ATMO_3D_DIRECT_SOLAR = 1 << 0 , CS_RAD_ATMO_3D_DIRECT_SOLAR_O3BAND = 1 << 1 , CS_RAD_ATMO_3D_DIFFUSE_SOLAR = 1 << 2 ,
  CS_RAD_ATMO_3D_DIFFUSE_SOLAR_O3BAND = 1 << 3 , CS_RAD_ATMO_3D_INFRARED = 1 << 4
void cs_rad_transfer_finalize (void)
 Finalize radiative transfer module.
bool cs_rad_time_is_active (void)
 Is time step for radiative transfer active?
const char * cs_rad_transfer_model_name []
const char * cs_rad_transfer_quadrature_name []
cs_rad_transfer_params_tcs_glob_rad_transfer_params
◆ anonymous enum
anonymous enum
Enumerator
CS_RAD_ATMO_3D_NONE
◆ anonymous enum
anonymous enum
Enumerator
Grey or black wall with temperature based on fluid BCs
Grey or black wall with 1D wall model
Grey or black wall with imposed exterior temperature; interior wall temperature computed through a flux balance
Reflecting wall with imposed exterior temperature; interior wall temperature computed through a flux balance (same as CS_BOUNDARY_RAD_WALL_GRAY_EXTERIOR_T with zero emissivity)
Grey or black wall with imposed conduction flux; interior wall temperature computed through a flux balance
Reflecting wall face to which a conduction flux is imposed, which is equivalent to impose this flux directly to the fluid.
◆ cs_rad_quadrature_type_t
Enumerator
◆ cs_rad_transfer_model_t
Enumerator
CS_RAD_TRANSFER_DOM
CS_RAD_TRANSFER_P1
◆ cs_rad_time_is_active()
bool cs_rad_time_is_active ( void )
true if active, false otherwise.
◆ cs_rad_transfer_finalize()
void cs_rad_transfer_finalize ( void )
◆ cs_glob_rad_transfer_params
cs_rad_transfer_params_t* cs_glob_rad_transfer_params
extern
◆ cs_rad_transfer_model_name
const char* cs_rad_transfer_model_name[]
extern
Model name
◆ cs_rad_transfer_quadrature_name
const char* cs_rad_transfer_quadrature_name[]
extern
Quadrature name
