| cs_sles_it_t * | cs_multigrid_smoother_create (cs_sles_it_type_t smoother_type, int poly_degree, int n_iter) |
| | Create iterative sparse linear system solver info and context used as a smoother in a multigrid solver.
| void | cs_multigrid_smoother_destroy (void **context) |
| void | cs_multigrid_smoother_setup (void *context, const char *name, const cs_matrix_t *a, int verbosity) |
| | Setup iterative sparse linear equation solver in case of used as a multigrid smoother.
| cs_sles_convergence_state_t | cs_multigrid_smoother_solve (void *context, const char *name, const cs_matrix_t *a, int verbosity, double precision, double r_norm, int *n_iter, double *residual, const cs_real_t *rhs, cs_real_t *vx_ini, cs_real_t *vx, size_t aux_size, void *aux_vectors) |
| | Call iterative sparse linear equation solver.
| void | cs_multigrid_smoother_free (void *context) |
| void | cs_multigrid_smoother_log (const void *context, cs_log_t log_type) |
| cs_sles_it_type_t | cs_multigrid_smoother_get_type (const cs_multigrid_smoother_t *context) |
◆ cs_multigrid_smoother_t
◆ cs_multigrid_smoother_create()
- Parameters
| [in] | smoother_type | type of smoother (CG, Jacobi, ...) |
| [in] | poly_degree | preconditioning polynomial degree (0: diagonal; -1: non-preconditioned; see Iterative linear solvers. for details) |
| [in] | n_iter | number of iterations to perform |
- Returns
- a pointer to newly created smoother info object, or nullptr if not available for this solver type.
◆ cs_multigrid_smoother_destroy()
| void cs_multigrid_smoother_destroy |
void ** | context | ) |
◆ cs_multigrid_smoother_free()
| void cs_multigrid_smoother_free |
void * | context | ) |
◆ cs_multigrid_smoother_get_type()
◆ cs_multigrid_smoother_log()
| void cs_multigrid_smoother_log |
const void * | context, |
cs_log_t | log_type ) |
◆ cs_multigrid_smoother_setup()
| void cs_multigrid_smoother_setup |
void * | context, |
const char * | name, |
const cs_matrix_t * | a, |
int | verbosity ) |
- Parameters
| [in,out] | context | pointer to iterative solver info and context (actual type: cs_sles_it_t *) |
◆ cs_multigrid_smoother_solve()
| cs_sles_convergence_state_t cs_multigrid_smoother_solve |
void * | context, |
int | verbosity, |
double | precision, |
double | r_norm, |
int * | n_iter, |
double * | residual, |
const cs_real_t * | rhs, |
cs_real_t * | vx_ini, |
cs_real_t * | vx, |
size_t | aux_size, |
void * | aux_vectors ) |
- Parameters
| [in] | a | matrix |
| aux_vectors | optional working area (internal allocation if nullptr) |
- Returns
- convergence state
